- 07-05-2012, 08:17 AM
Thread Author #1
- 07-05-2012, 10:26 AM #2
- 07-13-2012, 03:05 AM #3
Re: Battery Disconnected Warning
I don't know if I could bring myself to drop in my GALAXY NOTE lol. If that worked then your connector pin on the actual phone that connect to the battery might have been jammed. Next time or to anyone having this problem just carefully free up the connector with a finger or paper clip. Hope this helps somebody, & remember ANDROID IS THE FUTURE - KID ANDROID.
- 07-28-2012, 11:28 AM #4
Send it for service! I It's a known issue with the tiny battery port!
It damages easily and is only compatible with Samsung assecories. I damaged the port using a blackberry micro usb cable which was slightly tighter fitting and the constant forcing it in damaged the tint port!
Sent from my SGH-I717R using Android Central Forums - 10-09-2012, 08:40 PM #5
I have found this to be the battery in my case, it is not that the battery was bad, it was that the casing around the contacts had become distorted from using an external charger. I used a really sharp knife and removed the affected border between the contacts and the phone is perfect, so have a look at the 3 contacts that mate to the phone and look with the battery installed to see that each of the contacts is sitting firmly against the mating surface. I have had this happen to 2 batteries now, both aftermarket batteries, the original (so far) is still good. This may not fix everybodie's "disconnected battery" warning, but it will surely help someone else out there!
- 11-11-2012, 11:33 PM #6
- 11-11-2012, 11:35 PM #7
- 11-14-2012, 09:56 AM #8
- 11-22-2012, 01:28 AM #9
- 11-23-2012, 01:02 AM #10
- 11-24-2012, 07:20 AM #11
- 12-07-2012, 11:28 PM #12
My god. You're all....... Awesome.....
I'll tell to everyone drop their phone everytime they got problem. Lol.
:banghead:
Sent from my GT-N7000 using Android Central ForumsI Jiraiya. The Epitome of Manliness.
- 02-10-2013, 09:31 AM #13
- 03-20-2013, 07:50 PM #14
- 03-30-2013, 04:30 PM #15
- 04-08-2013, 05:53 AM #16
Okay that was definitely trolling, i thought to myself. I am not going to drop my S3 -untill my battery reads 8% and i figured i gotta do something about this...
After some intense browsing, i got frustated and thought what the heck. U cast this on urself galaxy... so i open everything and throw my phone to the sofa (hey it's hard leather), gave the docking area a couple of furious taps... and when i plugged the charger, it's charging!!!
So yeah, as ridiculous as it may sound, it works.
There's probably a wobbly part around there that would get back into its rightful position with a little nudge - 04-09-2013, 02:56 AM #17
- 04-27-2013, 03:31 PM #18
- 05-18-2013, 05:46 PM #19
- 05-21-2013, 10:29 PM #20
tried every thing (remove the battery and wait an hour, try a different battery,clean the micro USB port, put a piece of tape/paper on the bottom of the battery, cleaning the pin..charging point) but the problem could'nt resolved........ and then i decided to drop my S2 on tabel ...........HEHEHEHE
AND NOW ITS WORKING PERFECTLY........... sorry dude you advice seems insane but i must admit......IT WORKS, THANKS A LOT
Reply
