Hi guys,
Hope you're all well.
I'm new to this forum and counting on your help.
I've had some really annoying issues with my Samsung Galaxy note battery. I believe it simply doesn't fully charge anymore. A couple of weeks back it started saying 'battery fullycharged, please unplug charger' and when I do it turns out it's not 100% but sometimes as little as 45% or 60%. If I unplug it and then plug it in the message would reapper again and again after a few minutes which is really annoying. I can't charge my phone overnight anymore because I'm unable to monitor the progress of charging.
Please help.
It's not the first issue I've had with battery and charging. about a month ago my phone would indicate that it was plugged in and charging when it wasn't. I fiddled with the little metal inside where you use to plug in your phone. it worked but now thing seems to be mucked up too.
Thanks.
Please help.
Thanks.
