Hello all,
I've rooted my Galaxy Note with ClockworkMod recovery successfully and then busybox.
Then I went to recovery mode again (after restarting the phone), however it loaded Android regular recovery mode (not Clockwork), so I installed Clockwork again and without restarting performed WIPE DATA (maybe that was a mistake?). After it was finished it restarted by itself and now its in the following status:
- stucks at GALAXY NOTE N7000 logo. Sometimes blinks, but never goes beyond it.
- Recovery mode exactly same - stuck at logo.
- when plugging USB it will show the battery, but it's like stuck then.
- Tried download mode, but it's stuck at Downloading... forever.
I couldn't find the exact case as mine, that it restarted by itself and stuck at logo now.
I backed up everything, the previous ROM and etc.
I am aware of the bricking bug of ICS, however I had the ClockworkMod installed, so what did I do wrong??
And most importantly, what should I do now? Can I do something via the download mode? I don't think Odin recognizes any connected device when I plug in the USB, but I don't know how to check if it does or not..
Thanks in advance!
EDIT: Advancing slowly.. managed to install cyanogen 9 mod, but now it stucks in the loading of the mod forever.. Can access recovery and download modes.
Thanks in advance!
