1. vincivasudevan's Avatar
    Hi,
    I have a Samsung Galaxy Note 1, which came with ICS initially. For the past one year i did not get any update for the OS. Hence I tried to install JB. I have downloaded the official version of Android Jelly Bean for samsung galaxy note 1 itself. Successfully installed the same and the phone has been working incredibly well.. I loved it... Recently i got an update for the same and i did update the same. When i checked the "About Phone " menu, the details are as follows
    Model No
    GT- N7000
    Android Version
    4.1.2
    Baseband Version
    n7000xxlso
    Kernel Version
    3.0.31-1042183
    Build Number
    JZO54K.N7000ZSLO2
    After update I could see that the proximity sensor does not work as desired. The display does not turn off even on call or even when the phone is unused. I have even set the screen time out to 15 sec.Since the screen turn off functionality is not working as desired, the battery drains off so fast and the phone also gets heated up.
    I have downloaded android sensor ( an application to check the status of all sensors) , it shows that the proximity sensor works fine.
    Has anybody faced this kind of an issue?? Can Anyone help me in this regard... Thanking you in advance..
    04-20-2013 04:35 AM
  2. sfingerh's Avatar
    Hi,
    I do have the same issue. I am still trying to turn it off.
    Did you solved it?
    06-01-2013 07:27 AM
  3. abdelrahman8's Avatar
    i have that problem but what is the full name of the application . to download and fix the issue . and where to download it ?? google play ??
    06-05-2013 07:04 AM
  4. Kasun Harshaka's Avatar
    Are you Know How To Repair it?
    04-03-2014 07:46 AM
  1. Battery issue on samsung galaxy note 10.1
    By in_translation in forum Samsung Galaxy Note 10.1
    Last Post: 07-27-2016, 02:11 AM
  2. Samsung Galaxy Note 2 automaticlally turning on WIFI again and again
    By Sakib Ahmed in forum Samsung Galaxy Note 2
    Last Post: 12-09-2013, 11:22 AM
  3. Samsung Galaxy Note 2 Battery Issues
    By Logesshwar Balasubramanian in forum Samsung Galaxy Note 2
    Last Post: 05-24-2013, 02:37 PM
  4. Noob Question: Gmail syncing issues on the Samsung Galaxy Note 2
    By Madkatter in forum AT&T Galaxy Note 2
    Last Post: 02-25-2013, 09:31 PM
  5. Samsung Galaxy Note II hits UK on October 1st
    By maxburn in forum Samsung Galaxy Note 2
    Last Post: 09-25-2012, 09:00 AM
