Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Techngro
  • 1 Post By rick2210
    rick2210's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default HELP - I have a messed Up Galaxy Note SGH-i717
    HELP!!!!!!!!!!!!!!
    I recently bought used i717 on Ebay. It is supposed to be unlocked but have not been able to confirm as the standard code does not work. Have not been able to root as superoneclick does not work. Finally got it to connect to Kies but Kies states latest ROM is installed.
    When I go to Settings >>> About Phone - Model Number is Samsung SGH-i717, Android Version 2.3.6, Baseband Version T989UVKL1, Kernel version 2.6.35.11, Build number Gingerbread.UCLA1
    When I boot up the ATT logo stuff is displayed and there was a bunch of ATT bloatware apps installed, most of which I deleted as I do not use ATT
    Don't remember where I was but on one web site about upgrading stated that baseband version should be I717UCLA1, I717UCLF6, or I717UCMB4 before updatingand that It will be I717UCMD3 after the update.
    I have discovered that the Baseband Version T989UVKL1 is for an SGH-T989, T-Mobile Samsung Galasy S II, which is probably the reason it won't update through Kies.
    I want to upgrade to Jelly Bean 4.1.2.
    Have considered Cyangenomod but afraid that with the non-ATT baseband I might brick it.
    Any help will be greatly appreciated. I am new to this and it has been very confusing so far.
  2. #2
    Techngro's Avatar
    Posts
    Global Posts
    7 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: HELP - I have a messed Up Galaxy Note SGH-i717
    You might be able to resolve the problem with an Odin back to the stock AT&T firmware, root, and then upgrade to whatever ROM you'd like.
    Honestly, your best bet would be to head over to XDA and post your question there. I don't know how many people are still using the original Note (I had one until a few months ago), but anyone who is and is knowledgeable enough to help you would be on XDA. So find the AT&T Note forum and post your question there.
    rick2210 likes this.
    rick2210's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Took your advice and posted on XDA - AT&T Samsung Galaxy Note i717 forum
    tube517 likes this.
  4. #4
    tube517's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Decks Reloaded,RebelROM
    Quote Originally Posted by Techngro View Post
    I pop in the Note XDA forum once in a while and they have (CM based) KitKat ROMs for the Note that work nicely. Still a solid phone. Hopefully the OP can get straight over there.
  1. AT&T Note 3 email security signing problems
    By littlelawdg in forum AT&T Samsung Galaxy Note 3
    Last Post: 01-24-2016, 07:13 PM
  2. Internet is slow on my Samsung Galaxy Tab Pro 10.1
    By skyguy737 in forum Samsung Galaxy Tab Pro 10.1
    Last Post: 05-23-2014, 05:19 PM
  3. [Q] Issue with flashing phone. Please help.
    By abc08234 in forum Sprint Galaxy S3
    Last Post: 03-16-2014, 09:19 AM
  4. Replies: 1
    Last Post: 03-15-2014, 09:48 PM
  5. Samsung Galaxy Nexus 4.2.2 Text Message Delay
    By Fuee in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-15-2014, 09:33 PM
