Results 1 to 5 of 5
    Sydney Hodge's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Exclamation i717 Audio Problems! PLEASSSSE HELP
    I have done everything I can think of. What happens is when I turn the phone on, it automatically thinks there's headsets in it when there's not. I even disconnected the audio jack & it's still reading it. I need help, any advice would be great & appreciated.
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    77,957 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Default Re: i717 Audio Problems! PLEASSSSE HELP
    Welcome to Android Central! What do you mean by disconnecting the audio jack? Did you actually open the phone up and remove the hardware connection?
    And you don't have your Bluetooth on, right?
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by B. Diddy View Post
    Thank you & I opened the phone & did it & my bluetooth isn't on, but if i connect it, it works. If i call someone, it uses my regular speakers, but then i can't use my headsets.
  4. #4
    B. Diddy's Avatar
    Posts
    Global Posts
    77,957 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    And I assume you've tried a system cache partition wipe and/or a factory data reset? If so, then it may be a hardware defect. Since you opened the phone up, that presumably voids the warranty (if it was even still under warranty, that is).
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i've had the phone for awhile. i was wondering what can make the headset short out like that?
  1. Help - Sideloading Apps
    By trisha3010 in forum Samsung Galaxy Gear
    Last Post: 05-13-2014, 05:00 AM
  2. Google Search problems on Galaxy Note 8.0
    By mymooski1978 in forum Samsung Galaxy Note 10.1
    Last Post: 05-11-2014, 10:02 AM
  3. Gmail android problem
    By dougltc in forum Android Apps
    Last Post: 05-07-2014, 11:04 PM
  4. Problem accessing SD card memory and disappearing Apps
    By Chippy193 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 05-07-2014, 01:38 PM
  5. Replies: 0
    Last Post: 05-07-2014, 12:21 PM
