Results 1 to 2 of 2
    Default My Galaxy Note won't connect to Samsung Kies
    Hi,
    I just got a used Galaxy Note (I have no experience in buying used Android phones) and it has Android 4.0.4 in it and it is rooted, it has the SuperSU (or something) app in it.
    I wanted to update it to 4.1.2 by connecting it to my computer but Kies won't connect to it. I can easily access the external storage in Windows Explorer but I can't see it in Kies.
    Should I reset my device or should I use some ROMs I have heard about?
    Please help.
  2. #2
    Default Re: My Galaxy Note won't connect to Samsung Kies
    Quote Originally Posted by ahmedbatty View Post
    Hi,
    Please help.
    you product code needs to match firmware code , it is bit difficult
    but if your firmware code matches the product code you will get kies update...
    Dont' Forget to press Thank you button and like button when you get an answer
    Thanked by:
  1. My gallary is doing my head in !!?
    By Tony Bird in forum HTC One (M8)
    Last Post: 05-19-2014, 09:21 AM
  2. Possible to Cut a Droid Bionic Sim Card for use in a Note 3?
    By ckranger11 in forum Verizon Samsung Galaxy Note 3
    Last Post: 05-18-2014, 09:10 AM
  3. Creating Leaderboard for my android app
    By JOYCE-CH in forum Software Development and Hacking
    Last Post: 05-18-2014, 01:14 AM
  4. Workaround for Samsung Galaxy S5 SD Card for Audible
    By Tom Dean in forum Samsung Galaxy S5
    Last Post: 05-18-2014, 12:21 AM
