Page 2 of 2 FirstFirst 12
Results 26 to 40 of 40
Like Tree20Likes
  1. #26
    Default Re: Phone says battery is charging when it's NOT plugged in.
    Hi,
    my problem WAS exactly the same as the others...
    but after I 'fixed' it, now when I put the cable of the charger in, (even if its not pluged)
    the phone turns off, and does not react... black scrren.. nothing..
    Have tu take out the battery, put it in again, and than it turns on.
    And again when I put the cable in, it turns off again ...
    If you have any idea, thnx
  2. #27
    Talking Re: Phone says battery is charging when it's NOT plugged in.
    Many thanks sir. You're the best!
  3. #28
    Awesome thanks .. It got worked now.....
  4. #29
    --- I had a similar problem with some phones and found it to be software in the phone I know its sounds weird but what all I tend to do is just turn off the phone for about 5 minutes with battery out which clears resident memory, turn it back on and put charger adapter in leave it for a few minutes then remove the adapter either at 100% but unplug charger from the wall first so that the transformer in charger discharges energy this will help preserve the life of your battery as well by the way and it should reset the flag pointer in the memory to the phone telling it the charger is disconnected and should not beep again.. its a bug in a lot of phones that's never have been corrected. A little tip do the same with your laptop charger unplug it from the wall and let it discharge first you'll be surprised how long your laptop battery lasts.
    Nick
  5. #30
    Cool Re: Phone says battery is charging when it's NOT plugged in.
    Thank You very much..
    I was struggle with this issue for the past 2 days, I felt to give my phone to the Samsung service center.. I tried your Solution it's really worked me..
    Thanks for the Simple solution as given for the public.. You save my money
    Thanks a lot..
  6. #31
    You Are The Saviour <3 Thanks A Lot I Got Tips For Repairing Dads Phone
  7. #32
    I keep having the same problem. My phone would keep making that noise everytime it wants to charge but it isnt on charge and nor is it plugged in. I have a Samsung Galaxy Ace by the way.
    help...please...
  8. #33
    Thanks 4 your help! Samsung port suxxx
  9. #34
    Nick, unplugging the transformer from the wall prior to unplugging it from the device does not improve battery life. It doesn't set any "pointer flags". This is nonsense.
  10. #35
    Ok. good needle advice
    ... when I lift the middle plate and turned it on it seems worked
    because my phone did not even turn on as it keeps charged and uncharged but it turned on and I was like "hooray" but suddenly when I closed the back it starts again so this time I put the needle at the centre of the plate and lift it with moving left and right and NOW "Hooray" it worked
    Phineas Delano likes this.
  11. #36
    Hi All,
    It's worked for me also.Many Thanks.
  12. #37
    Thumbs up Re: Phone says battery is charging when it's NOT plugged in.
    thanx so much this has fixed my phone
  13. #38
    thanks, this procedures help me to solve my problem.
  14. #39
    It worked. Thanks a lot. Basics work brilliantly at times.
  15. #40
    Kudos it worked and am glad for your help!!!
B
