06-30-2016 04:23 AM
65 123
tools
  1. MrScottMairs's Avatar
    FINALLY!!! Thank you so much. It worked!
    01-15-2015 10:47 AM
  2. Jenifer Fetzer's Avatar
    --- I had a similar problem with some phones and found it to be software in the phone I know its sounds weird but what all I tend to do is just turn off the phone for about 5 minutes with battery out which clears resident memory, turn it back on and put charger adapter in leave it for a few minutes then remove the adapter either at 100% but unplug charger from the wall first so that the transformer in charger discharges energy this will help preserve the life of your battery as well by the way and it should reset the flag pointer in the memory to the phone telling it the charger is disconnected and should not beep again.. its a bug in a lot of phones that's never have been corrected. A little tip do the same with your laptop charger unplug it from the wall and let it discharge first you'll be surprised how long your laptop battery lasts.
    Nick
    01-16-2015 06:54 PM
  3. Jenifer Fetzer's Avatar
    I am going to try this with both!
    01-16-2015 06:55 PM
  4. AliefLuthfi's Avatar
    i have the same problem. The battery keeps charging even when it's not plugged in.
    but I tried the needle stuff, and it didn't work.
    I think that there is nothing wrong with my port, maybe?
    when i charge it, it's charging, and and when i unplug it, it's still charging.
    Please help me? or is it because I was stuck in the rain earlier with my phone inside my pocket?
    does it have something to do with water thing?
    01-28-2015 11:30 AM
  5. pammidaid's Avatar
    Really running short of words to THANK YOU. It really worked. Thanks again and again
    03-06-2015 10:27 AM
  6. Rajan Dey's Avatar
    Hi,
    my problem WAS exactly the same as the others...
    but after I 'fixed' it, now when I put the cable of the charger in, (even if its not pluged)
    the phone turns off, and does not react... black scrren.. nothing..
    Have tu take out the battery, put it in again, and than it turns on.
    And again when I put the cable in, it turns off again ...
    If you have any idea, thnx
    05-03-2015 05:20 AM
  7. lang1956's Avatar
    Unplugging the transformer from the wall worked for me! Nick you are on to something here. I've had this issue and tried everything. Even had my phone replaced once. I do think it's a software issue, but letting the excess power drain back to the transform make perfect sense. Thanks!
    05-22-2015 06:51 AM
  8. jgvCakes's Avatar
    Is there any other way to fix this problem? I've tried this and it still keeps going back and fourth with the charging thing. The only thing that's been working out for me is rubbing alcohol, but it doesn't last longer than an hour.
    08-14-2015 07:03 PM
  9. Brent Samsung's Avatar
    My Daughters Phone Pulled that same thing on us. we took the battery out while the phone was turned on and Plugged in, waited for it to shutoff and then put the battery back in, it hasn't done it since....
    Thanks worked (although mine was a tablet that had this problem)
    12-11-2015 04:09 PM
  10. Sarah Poulin's Avatar
    My Daughters Phone Pulled that same thing on us. we took the battery out while the phone was turned on and Plugged in, waited for it to shutoff and then put the battery back in, it hasn't done it since, IF that doesn't FIX IT i would suggest taking it back to where you got it for replacement if it was walmart they only have a 15 day return/replace policy on these phones so if its been longer than that i am affraid the only other thing you could do at that point is send it to Samsung for Repairs.
    YES!!! This is what worked for me. I tried cleaning out the port, I tried bending the little thingy in the port back toward the middle more... and it didn't work. Tried this method of having the phone on, leaving it plugged in, pulling the battery and letting it shut off, then I unplugged it, and put the battery back in. Booted up the phone, and the charging symbol didn't show! Plugged it in, said charging. Unplugged it, stopped charging! Thanks!!!!!!!
    12-27-2015 06:01 PM
  11. elcadejo's Avatar
    i took the battery away while on. then cleaned and gently separate the contacts a little with a cutter's edge
    it worked. thanks for the tips!
    Greetings from El Salvador.
    02-18-2016 11:43 AM
  12. Trigger Brewer's Avatar
    I tried all this but mine still want stop saying its charging
    02-22-2016 06:26 PM
  13. Lonnie Herrington's Avatar
    is there a video for this? i dont get it iv tried multiple times
    06-10-2016 09:20 AM
  14. Arjay Rosel's Avatar
    what if my phone is built in battery?
    06-27-2016 12:53 AM
  15. himanshu123456's Avatar
    i am having moto g 3rd generation, i am facing problem in my phone that when i connect charger its not start charging, when i switched it off and let the charger connect its showing charging, but when i turned it on its showing charging but actually not charging.
    also its showing charging sign even when charger not connected.
    06-30-2016 04:23 AM
65 123
