Results 1 to 3 of 3
    Default need help!!
    not sure what to do. i have transferred my number from one phone to the samsung galaxy precedent. straight talk says the transfer is complete and that i should be able to update the profile and the prl...but every time i try to update it says connection error and doesn't update. i cannot use my phone unless this updates. i have full bar for signal. suggestions?????
  2. #2
    Default Re: need help!!
    Have you tried rebooting the phone, unplug the charger shut down the phone, take out the battery for a few seconds, then put battery back in and turn on the phone then try the updates?
    If that doesn't work then you may have to call customer support and double check that they have the correct info for the phone.
    Hope that helps.
  3. #3
    I learned that you must be in an area that services a 3g connection. I live in a small town and in order to update any profile I have to drive 35minutes away to a place that has a 3g connection service area.
  1. New to Android phone and need help
    By ntapia82 in forum Samsung Moment
    Last Post: 04-26-2010, 05:40 PM
  2. Android Rookie with the HTC Hero I need help!!!!
    By bigrich34 in forum HTC Hero
    Last Post: 10-14-2009, 12:15 PM
  3. getting started, need help !
    By android for dummy in forum General Help and How To
    Last Post: 09-24-2009, 08:28 AM
  4. Need help regarding my google search bar on my g1
    By wabbit3119 in forum General Help and How To
    Last Post: 09-01-2009, 04:41 PM
  5. need help please
    By jfchica1987 in forum T-Mobile G1
    Last Post: 06-16-2009, 02:12 PM
