Hi all,
I'm long time lurker and first time poster.
Recently just got the Skyrocket and noticed that using the LTE speed, data usage is used up extremely fast and on a 4 Gig limited data cap it would be great to have the ability to switch over 2G/3G signal.
Is there was a way to create a new APN to enable 3G or Edge speed?
I know the LTE radio can't be turned off on this device but there must be a way to modify the APN settings for lower speed.
Thanks!
