1. dmarquand's Avatar
    I have this re-occuring problem with the media volume being very low even at full blast. I've tried it on three headphones so I know its the phone. Rebooting it works great, but I need a full solution.
    I'll start to notice the battery status when this problem keeps happening, I was thinking it may be due to low battery?
    11-30-2011 09:57 PM
  2. fanofdean's Avatar
    Maybe part of the powersaving feature?
    11-30-2011 10:35 PM
  3. dmarquand's Avatar
    I wish, but it's doing it right now at 90% battery
    12-01-2011 12:12 AM
  4. CZ Eddie's Avatar
    When it does this, is the media volume set to 100% on the slider bar?
    Sometimes the apps may adjust the volume for whatever reason.
    If it's at 100% then I dunno. You might try clearing your davlick cache to see if that helps.
    Or reflash if you're on a custom ROM.
    12-01-2011 09:00 AM
  5. dmarquand's Avatar
    Thanks, but I found out it was all PlayerPro's fault. That's the only thing I use for media sound. I downloaded PowerAmp and its much better.
    12-01-2011 10:34 PM
