Results 1 to 11 of 11
- 12-20-2011, 07:09 PM
Thread Author #1
Does the skyrocket have LED hardware?
I downloaded light flow and it isn't working. I read light flows FAQ page and didn't find anything. Any help would be appreciated.
- 12-20-2011, 08:18 PM #2
Re: Does the skyrocket have LED hardware?
No notification LED on this thing. Only LED I've seen is the camera flash. Coming from BlackBerries, it's probably the only thing I miss.
- 12-20-2011, 08:29 PM
Thread Author #3
Me too as Ive been a blackberry user. Android seems to be superior in all other aspects though. Thanks for the reply.
- 12-20-2011, 09:05 PM #4
- 12-21-2011, 05:51 AM #5
Out of the whole phone, this is the only thing I was dissapointed to not see on this phone. I really miss it coming from the OG Droid. Mainly because now if I walk away from my phone or I'm sleeping, I don't have an LED light to tell me I have a missing text, call, or email.
Nexus 4 (Feb 2013 - Present)
Samsung Galaxy S2 Skyrocket (2011-2013)
Verizon OG Droid (2009 - 2011)
ASUS Transformer Pad TF300 (May 2012 - Present) - 12-21-2011, 01:57 PM #6
Flashlight Alerts uses the camera flash LED as your Notification LED for Calls, Texts, Email, Gmail, K-9, etc. Tutorial.— Milo
← Tap Getting Started at the top of any page for help with:
- Settings - Email - Backup Everything - Phone - Messaging - Music & Photo Sync
- Keyboards — Folders - Favorite Apps - Extending Battery Life - My Avatar
- iPhone User's Guide to Android - (Palm) - Tablet & Phone Comparison - Epic4GT - ATT - TM
If this helped, please click ↓Thanks & Like↓ - 12-21-2011, 05:11 PM
Thread Author #7
I downloaded NOLED but uninstalled it because I can't get it to work with GOSMS. I get double notifications, any ideas?
- 12-22-2011, 07:31 PM
Thread Author #8
Any ideas?
- 12-23-2011, 05:12 AM #9
Give this a shot
1) Go into the stock/native messaging app and go into the settings and turn off notifications (even though you probably told gosms to turn them off for you)
2) In noled look under toggle notifications / monitored apps and check gosms. Then look icons and make sure other icons is checked
Good luck, hope this helps. - 12-23-2011, 05:14 AM #10
Now I have a question. How much of a battery hog is this thing? I really miss my notification led from my atrix and figured I'd go ahead and give this a shot but really don't want to sacrifice much more battery power.
- 12-27-2011, 03:12 PM #11
From what I've heard/read AMOLED displays only light up the pixels needed. SO if you use this, only the pixels lit by notifications are on. Rest of them are apparently off.
That's why the Blacks on AMOLED displays are so black, since they're just pixels that are off.
Reply
