Results 1 to 4 of 4
    Default Battery not charging properly.
    Replaced my battery a week ago due to the last one not charging. A week later and now the new one is doing the same. Not the same draining issue, but not getting it to charge fully. Completely stock.
    Any ideas?
    Sent from my Samsung Galaxy S2 Skyrocket SGH-i727 on ATT LTE
  2. #2
    Default Re: Battery not charging properly.
    Are you using the original skyrocket charger and USB?
    Default
    Quote Originally Posted by Trevalkin View Post
    Yes. Going to back up and to a hard reset. If that doesn't fix, then they can replace it...
    Getting the SGSIII in a week or so anyway, was hpoing to sell my skyrocket though...
    Default
    Backup with kids, hard reset, and still seem to have the issue. Hopefully Samsung will replace....
    Sent from my SAMSUNG-SGH-I727 using Android Central Forums
