Upgraded to ics. How do I get widgets onto the lock screen? I thought we were supposed to be able to access the camera or other apps from the lock screen. And how do I add additional emergency numbers to the lock screen? The thing they call ICE.
It's not there!
If I could figure out how to post a screenshot I would show you. the screenshot is dim in the clipboard, so I can't select it.
Before ics, when I captured a screen, it went into a gallery folder called ScreenCapture. Now it goes into a gallery folder called screenshots.
The easy way to do it....
go in to contacts
go in to groups
add group
type 'ICE' as group name
add contact details now or later( doesn't matter)
select 'done'
you should now see that you have a new group called ICE-emergency contacts
when you are on the key lock screen, select emergency numbers
select the symbol of a person with an emergency light
your contacts should now be displayed B-)
