Results 1 to 7 of 7
    Thumbs down having call problems with cm10.1
    Ever since the nightly of cm10.1 of February 20 to march 8. Every time I update my phone using the cm updater with clockworkmod bysk8 14.4.6
    Well when I update once or twice when I call it goes through but no ringing I can't hear them and they can't hear me is it the noise suppression or what? When I do a full wipe and install the new update all is fine . I haven't tried manually using cwm to update the nightly
    Please help
  2. #2
    Default Re: having call problems with cm10.1
    Quote Originally Posted by talelorm View Post
    Please help
    Its a known issue a clean reflash works until a couple reboots and then the issue comes back. My suggestion is to use the last nightly that works for you (for example mine is 2/26) until an official fix is implemented.
    Sent from my SAMSUNG-SGH-I727 using Android Central Forums
    So if I never let the battery die or reboot I should be ok ? Flashing an older nightly would work too
  4. #4
    Well it breaks during upgrades too.
  5. #5
    It's been fixed.
    Look at and .
    Should be in one of the next Nightlies.
    Sent from somewhere in Galaxy S2...
  6. #6
    Jacques's Avatar
    Greetings, program!
    Posts
    Global Posts
    305 Global Posts
    ROM
    Cyanogenmod 10.1 nightly
    To add to what DanoNH said, it's the 3/9 CM build, but it doesn't include a commit in the system/core that causes a break in the call audio. I reverted back to the 2/26 build when this bug was first appearing, but when I have a moment, I'm going to flash roger_n's fix.
    Samsung Galaxy S2 Skyrocket--rooted and flashed CM10.1 nightlies
    Acer C7 Chromebook--stock, but not for long :-)
    HP TouchPad--dual-boot and ported CM9
    HTC Nexus One--my first Android (retired)
    Its not happened since I've flashed march 17 2013 nightly glad this was fixed
  1. is any1 else having a problem with calls or textin??
    By kingcaliyone in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 03-30-2012, 03:07 PM
  2. I still have a problem with QUESTION MARKS in phone numbers
    By eric0668 in forum T-Mobile Vibrant
    Last Post: 07-31-2010, 08:47 PM
  3. Replies: 1
    Last Post: 07-21-2010, 12:11 AM
  4. Replies: 3
    Last Post: 06-22-2010, 11:58 AM
  5. I'm having a problem with the Gmail app.
    By BurgesS in forum General Help and How To
    Last Post: 03-05-2010, 07:33 AM
