1. Elite Busido's Avatar
    so i found this;
    Amazon.com: 2200 mAh Extended Slim Design Battery for Samsung i997, Infuse 4G, (EB555157VA): Cell Phones & Accessories
    but it says its for the infuse. shouldnt this battery work with the GS2? i would thnk they use the same specs, as for batteries go
    09-02-2011 09:57 PM
  2. Kilted_One's Avatar
    just go on ebay and by a good extended battery for the S2
    09-05-2011 05:31 AM
  3. Broheemster's Avatar
    Somebody over at XDA tried swapping the two out and said they "definitely won't" interchange.
    09-05-2011 10:02 AM
  4. Elite Busido's Avatar
    thx
    i dont want a bulky battery. only ones i found ruined the thinness of the phone
    09-06-2011 05:36 PM
  5. Kilted_One's Avatar
    If you look on ebay not all extended batteries are bulky, the one I got is same size but way more powerful
    kalpeshaparmar likes this.
    09-07-2011 01:09 PM
  6. Elite Busido's Avatar
    which one is that?
    09-11-2011 09:12 PM
  7. kalpeshaparmar's Avatar
    Any link for the same?
    Sent from my GT-I9100 using Tapatalk
    10-20-2011 02:06 PM
