Results 1 to 6 of 6
    Default Led not working
    Manufacturer defect maybe? Network blocked Or do i need to root.
    Sent from my GT-I9100 using Android Central Forums
  2. #2
    gsainath4u's Avatar
    Posts
    Carrier
    Stock (ICS 4.0.3)
    Default Re: Led not working
    As far as I know, the Galaxy S2 does not have a Notification LED.
    The Red LED you see next to the Front Cam. is actually the Proximity Sensor which will be activated during calls, to turn the screen on/off. This can be activated/deactivated from the settings menu. "Settings -> Call -> Turn on Proximity sensor"
    DBKS2 likes this.
    Default
    Realized that after asking :rolleyes:
    Sent from my S2 using Android Central ForuMs
  4. #4
    gsainath4u's Avatar
    Posts
    Carrier
    Stock (ICS 4.0.3)
    No Problem. Many people make the same mistake
    Default
  6. #6
    off-topic's Avatar
    Posts
    Carrier
    Stock ICS 4.0.3
    Quote Originally Posted by DBKS2 View Post
    So you want to have a notification led?
    Try this one:
    Flash Blink
    Have fun!
