Results 1 to 2 of 2
- 12-12-2012, 06:33 PM
Thread Author #1
1/Wifi tether SSID. 2/Bluetooth audio transmitting.
Hi,
I am new in the forum, i hope i am doing right, i have tried to find answer to my question but without result, therefore please help :-)
Problem 1 ; Tether transmit SSID.
Problem 2 ; Bluetooth A2DP sound
Problem 1:
Problem with all jb roms i can find, they dont seems to be working with wifi tether transmitting >SSID< !
In all of the jb roms i have found and installed, (via .zip file,) it seems that the wifi tethering is turning on, but it will not transmit the SSID !
Is this a general issue or mabe my phone ? My wifi works perfectly.
I have also tried different tethering apps, with same result.
My stationary pc is on wifi, and i use it to scan for the SSID from the sgs2, but without result.
Problem 2:
Problem with bluetooth sound. It connects, and i have checked that voice and music is check marked in settings for bt, but it does not sent the music to the bt speaker !? It sends the music to rhe external speaker (I can paus the music on via the bt sevice, so it is proper connected)
At this moment i use following;
Rooted SGS2
GT-I9100
Android 4.1.1
X-Treme cm10 beta
I9100XXLPQ
Kernel: 3.0.36 cm build 25 juli
version JR003H
Please help :-)Last edited by ThaigerPinoy; 12-23-2012 at 11:14 PM.
- 12-23-2012, 11:23 PM
Thread Author #2
Sv: 1/Wifi tether SSID. 2/Bluetooth audio transmitting.
After updating to CM 10.1 JB 4.2.1
I am super happy for cm10.1.
Bluetooth works, but i still have problems with wifi tethering, it wont sent ssid !
Mabe my baseband or modem !
Pls hlp :-)
SGS2 CM10.1 JB4.2.1
TapaTalk /Thaiger
How to get wifi tether to work
By alex5252 in forum HTC Droid Eris Rooting, ROMs, and HackingReplies: 0Last Post: 04-18-2010, 07:54 PM -
Wifi tethering?
By manningfan10 in forum Motorola DroidReplies: 14Last Post: 03-30-2010, 07:50 PM -
2.1 with wifi tether
By droidman in forum Motorola DroidReplies: 4Last Post: 12-31-2009, 02:14 PM -
WiFi Tether on rooted Sprint Hero + Nintendo DS Lite?
By supermanly in forum HTC Hero Rooting, ROMs, and HacksReplies: 11Last Post: 11-25-2009, 02:17 PM -
Bluetooth Audio Doesnt work on Hero
By cpwinters in forum HTC HeroReplies: 1Last Post: 11-03-2009, 09:49 PM
Reply
