Results 1 to 10 of 10
- 02-05-2013, 06:35 PM
Thread Author #1
Not an option to turn off speaker sound with headphones plugged in?
Hi, everyone.
So I'm trying to figure out how to turn of the sound on the speakers while the headphones are plugged in. I am using this app to learn a language which I would like to use on my 20 minute bus rides to town, but I've tried every option in Settings to only make the sound come through the headphones, but without any luck. I've also Googled to find a solution to this problem, again without any luck. And only finding people speaking about the same issue.
Does anybody know how to solve this problem? I will worship your toes. - 02-05-2013, 10:51 PM #2
Re: Not an option to turn off speaker sound with headphones plugged in?
Is it possible that the problem is with the app that you are using to play the sounds. I use earphones every night and have used multiple MP3 players and Podcasts app and everyone of them automatically shuts off the sound from the speaker and only play from the earphone. Just to test you phone (I have an S3 versus your S2) download Rocket Player from the Google store and play an MP3 to see where the sound comes from.
Galaxy S3 16GB Unrooted Pebble Blue
Verizon,USA
Android V4.1.2 - 02-06-2013, 02:13 AM
Thread Author #3
- 02-06-2013, 08:05 AM #4
Yes, when you plug in the earphone the MP3 should play thru it and there should be no sound thru the phone speakers. If that is not the case with you then either the S2 is difeernent than any other phone that I have had or there is so,ething wrong with your phone. If you know someone else who has an S2 ask them or you can call your phone provider and they may help you.
Verizon,USA
Android V4.1.2 - 02-06-2013, 10:06 AM
Thread Author #5
Are you sure that all sound should automatically go through the headphones when they are connected? Because I've read dozens of other forums that when it comes to notification sounds, those must be turned off manually.
But I will take it to the store in which I bought it and ask them, most definitely. It shouldn't be like that. - 02-06-2013, 10:16 AM #6
I use a ear phone every night when I go to sleep and listen to podcasts and I never manually turn off the phone speakers. I have done this with my S3 and previosly with a Bionic and Thunderbolt.
Verizon,USA
Android V4.1.2 - 02-06-2013, 10:32 AM
Thread Author #7
- 02-06-2013, 10:54 AM #8
email notification sounds are thru the ear plug and so are calendar events. In my case I have an app Calendar Event Reminder which allows me to send the event alrams to my phone speakers instead of the ear plugs.
Verizon,USA
Android V4.1.2 - 02-06-2013, 11:07 AM
Thread Author #9
- 02-07-2013, 12:53 AM
Thread Author #10
Is there an option to turn on text reflow in the stock browser?
By saintforlife in forum Samsung Galaxy S3Replies: 2Last Post: 07-12-2012, 09:17 AM -
Why does AT&T not give us the option to turn off LTE?
By MattMJB0188 in forum HTC One XReplies: 40Last Post: 05-25-2012, 11:18 PM -
Help! ICS ROM with no option to turn off fastboot- cannot get in
By jamesbecker79 in forum Rezound Rooting, ROMs, and HacksReplies: 9Last Post: 02-17-2012, 08:57 AM -
How to turn off Notification sound when plugging in
By dmcrowe in forum Motorola Droid XReplies: 6Last Post: 05-24-2011, 10:58 PM -
Pandora: Sounds comes from internal speaker even with headphones plugged in?
By Atlienzz in forum Sprint Epic 4GReplies: 4Last Post: 09-02-2010, 08:57 PM
Reply
Not so smart phones? lol
