1. rupalazzi's Avatar
    Hello guys. Need your help. A friend got his I9100 wet, let it dry only 1 night and turn it on next morning. Now neither WiFi nor bluetooth are able to turn on. I alredy flashed stock firmware I9100XWLSW_I9100XEULS5_XEU and root it. Did a Factory Reset. No success.
    Can any of you give any ideas? is it a hardware or software issue?
    Thanks.
    07-10-2013 07:52 AM
  2. rupalazzi's Avatar
    Issue solved. some internals were sulfated.
    07-10-2013 09:44 AM
  3. Jethrick Hernandez's Avatar
    what should i do ? if internal is sulfated please answer thx
    09-02-2013 12:27 PM
  4. William Kupp's Avatar
    Experiencing the same issue with a Galaxy S4 ATT i337... seems like a system file issue... I got the S4 used and wondering if it had a custom ROM installed... there must be a way to reverse the custom rom so I can recover and restore the WiFi & Bluetooth features!?!
    09-03-2013 09:34 PM
  5. Alvin Sevilla's Avatar
    I have problem with my Cherry mobile Omega hd. ALL ARE FUNCTIONAL EXCEPT FOR THE BLUETOOTH AND Wifi. I bought it secondhand. the first owner says it all happens when he custom rom it with galaxy s4... guys kindly help me pls..
    09-11-2013 04:59 AM
  6. mightymo77's Avatar
    The problem is your modem and/or kernel. For the Samsung Galaxy S4, you can flash an updated modem fix via odin here: [REF] GALAXY S4 (I9500/I9505) GSM / NON-HLOS.bin - MODEM'S Collection (Odin/CWM/TWRP) - xda-developers
    The problem is I have no idea how to make out what files I need. None of those codes make any sense to me.
    09-21-2013 02:08 PM
  7. JM Dacanay's Avatar
    The same problem with me, I cannot tick the Wifi and bluetooth. Do you have any wifi or modem file for Omega HD sir?
    12-28-2013 01:36 AM
  1. NFC switches help
    By mpec82 in forum General Help and How To
    Last Post: 07-11-2013, 10:57 AM
  2. Text message help. Im a n00b
    By anna fancypants in forum Android Apps
    Last Post: 07-10-2013, 09:54 AM
  3. pdanet bluetooth tethering sucking my tablet battery fast!
    By Mitchell Gray in forum General Help and How To
    Last Post: 07-10-2013, 05:24 AM
