1. Helio Leung's Avatar
    Hi Guys.
    So for whatever reason i just found out that my samsung galaxy s2 (i9100)'s screen broke INSIDE. The LCD itself didnt have any cracks, but i saw a crack inside. The areas around the crack turned purple and the touch screen is glitchy as hell now. Some parts dont even respond. I told my parents and they just blamed me for dropping my phone. Any help??????? About how much does it cost to fix it????
    08-26-2013 11:00 AM
  2. Scott Kenyon's Avatar
    Replacement LCD and Touch Screen Digitizer for Samsung Galaxy S2 i9100 White - Tmart.com
    I'd check a few Youtube vids to ensure it's fairly simple to do. Some of these repairs are a pain.
    08-26-2013 11:11 AM
  3. deejayburnout's Avatar
    Best bet is to buy new screen.
    Cheap and simple to do yourself. There is a very good video on YouTube by a guy called lessons who takes you through step buy step.
    I followed his video and fully refurbished my phone.
    Word of advice. Get a screen that has the housing already attached as this makes the whole job a lot easier.
    Sent from my GT-I9100 using Tapatalk 2
    08-28-2013 02:51 AM
  4. Tabby Ann Ly's Avatar
    The S2 are merge so you have to buy the whole assembly. Assembly current as of Nov 2013 is around $70. Heres how to repair it:
    If you don't want to DIY than your going to have to take into a person or place to repair it.
    - - - Updated - - -
    11-19-2013 12:40 AM
  5. ivie emofonmwan's Avatar
    Okay i really need help guys.
    today i dropped my samsung galaxy s2 on the ground and the screen is really cracked, it keeps on showing the home signs that glow on the bottom but it wont turn on. and it doesnt charge either. sound works. what should i do?
    any help?
    07-23-2015 09:26 AM
  1. auto lock screen problem flip cover
    By darkfenrir in forum Samsung Galaxy Tab 3
    Last Post: 06-21-2015, 06:52 PM
  2. Galaxy SII Skyrocket Not recieving calls/texts
    By missquirky in forum AT&T Galaxy S II
    Last Post: 10-23-2013, 01:26 PM
  3. Bought Used Galaxy Nexus with 4.0.1 It won't update.
    By Christopher Massaad in forum Google / Samsung Galaxy Nexus
    Last Post: 08-27-2013, 10:12 AM
  4. I keep getting shortcuts added to my Galaxy S3 home screen??
    By hunnybunny666 in forum Samsung Galaxy 3
    Last Post: 08-26-2013, 10:36 AM
  5. help I don't have all the photo settings
    By androidgirl19 in forum Samsung Galaxy S4
    Last Post: 08-26-2013, 10:22 AM
