1. Ally Bell's Avatar
    Hey,
    I just got an unlocked S2 (which is a huge step up from the paper weight I had before!).
    Everything else is working fine on the phone but it isn't connecting to the wifi. It connected for maybe 5 mins a few hours ago but nothing else since.
    Im not sure what the carrier was before, its a Koodo phone thats all I know and Im with Bell.
    If anyone has any suggestions. Ive tried rebooting, airplane mode, Im not a huge techie so I don't really know what Im doing.
    So any suggestions would be super helpful!
    Thanks!
    03-10-2014 09:45 PM
  2. dctokyo's Avatar
    Do you have a Wi-fi router in your home?
    03-10-2014 09:58 PM
  3. Ally Bell's Avatar
    Yeah and the old phone I had picked it up no problem, and Im on my computer right now.
    03-10-2014 10:01 PM
  4. dctokyo's Avatar
    Is your router open or do you need a password to join?
    Connecting to wifi networks is easy, just goto Menu > Settings > Wireless and Networks > Wi-Fi Settings. From here, you can see avaliable wifi networks, and if they are password-protected. Any time you join a network, it will be saved and your device will join it automatically the next time you are in range. To forget a network, just click or long-press on the name and select "forget."
    So lets delete the network that you join before on your phone and try to re-add it. sometimes this helps
    03-11-2014 12:38 AM
  1. GSM unlocked Sprint HTC One Max
    By Bl00dRunzC0ld in forum Marketplace Archive
    Last Post: 03-15-2014, 07:26 PM
  2. Official part # from samsung to hdmi out my display onto a monitor?
    By Grimgrak in forum Samsung Galaxy Note Pro 12.2
    Last Post: 03-13-2014, 09:17 PM
  3. Help...need a decent ROM for my PT7510
    By auzziebob in forum Samsung Galaxy Tab 10-inch
    Last Post: 03-10-2014, 06:24 PM
  4. Need help with bootloaders
    By Headcase_Fargone in forum AT&T Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 03-10-2014, 05:58 PM
  5. HTC One Root Fail PLEASE HELP
    By Deron Buske in forum HTC One M7
    Last Post: 03-10-2014, 05:53 PM
