1. NotSoBrown's Avatar
    I wanted to get 4.3 on my phone because 4.1.2 wont let you use your SD Card for apps. That is all I wanted. Then I used ODIN to get twrp (cannot get cwm to work :/ ) It worked and i installed the ROM... then it happened. It would not boot, it got stuck in a loop. I took out the batter to get it in recovery again. I then put it into recovery again. No the touchscreen will not work. I have tried every version of twrp from 2.5.0.0 to 2.7.0.1 and nothing worked. I tried loading the ROMs with ODIN and they didn't show up because they were .zip files. I re-compressed them to .tar files then tried again. I got an error that said "Unsupport dev_type" So I gave up. Anyone know what to do? A program that can actually reset my phone to its factory default? Otherwise I have a $150 paperweight with no warrenty. Thank you for reading. (btw I went 7 hours straight trying to find a fix but found nothing.) My Mood:
    05-10-2014 08:54 PM
  2. mobilecrackers's Avatar
    If you can get into recovery then clear cache and data
    download a stock firmware and flash it with odin, only tick autoreboot and f-reset time
    After that again clear cache and data from recovery .
    NotSoBrown likes this.
    05-10-2014 10:19 PM
  3. NotSoBrown's Avatar
    As I said before I can get into recovery but I cannot tap on anything because the ROM I installed was not compatable with my phone. So I cannot do anything on there. I already thought of this and tried. If there is a way to load an old version of twrp or some other recovery booter, I would maybe be able to do it. (If it was with the volume buttons.)
    05-10-2014 11:25 PM
  4. mobilecrackers's Avatar
    Then you need reflash your phone using odin
    Ready to help you
    05-10-2014 11:33 PM
  5. NotSoBrown's Avatar
    Already did 13 times.
    05-10-2014 11:44 PM
  6. NotSoBrown's Avatar
    Think anyone could port cwm to the Galaxy Victory 4G LTE from Virgin Mobile?
    05-11-2014 12:05 PM
  7. NotSoBrown's Avatar
    well I guess I just have a $150 paperweight :/ unless someone can get cwm for my phone or fix the "Unsupport dev_type" error....
    05-11-2014 05:53 PM
  8. mobilecrackers's Avatar
    ODIN Tool
    TWRP Recovery
    Launch ODIN through its executable file in the extracted folder.
    Click on PDA button to choose TWRP Recovery from the downloaded location.
    Uncheck the following files
    Auto Reboot
    Re-partition
    5. Power down your Samsung Galaxy Victory 4G LTE.
    6. Now user need to get into Download Mode using Volume Down + Power keys combination.
    7. Press Volume Up key to confirm your action.
    8. Now connect your phone to the Computer/Laptop through USB cable.
    9. Finally click on Start button in ODIN to start flashing the phone with TWRP Recovery.
    You have done everything successfully. Now just reboot your phone and you will get your phone flashed on the boot up.
    05-11-2014 10:45 PM
  9. mobilecrackers's Avatar
    try this CWM link it may help
    05-11-2014 10:59 PM
  10. NotSoBrown's Avatar
    TWRP does not work because the touchscreen driver got deleted when i installed the custom ROM.. i can see the time change but when i tap it, it does not work... So i need to figure out how to get cwm into a tar file... well i have but it gets an error saying unsupport dev_type. so i dunno m8 :/
    05-12-2014 10:49 PM
  11. mobilecrackers's Avatar
    this will help you
    first clear cache then data from recovery then
    re flash again with 4.1.2
    make sure your phone is working ..
    05-15-2014 10:50 PM
  1. Help!!!
    By ki11aprime in forum General News & Discussion
    Last Post: 05-11-2014, 07:25 AM
  2. Note 2 Keeps Turning On after Lock Button is Pushed
    By Angelica Garcia in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 05-11-2014, 07:01 AM
  3. Somebody Help!!!! I cant return my phone back to stock
    By LordMarq in forum Samsung Galaxy S4 Mini
    Last Post: 05-10-2014, 10:37 PM
  4. screen not responding
    By Alisha Allen in forum Samsung Galaxy Tab 3
    Last Post: 05-10-2014, 10:34 PM
  5. Replies: 0
    Last Post: 05-10-2014, 06:52 PM
