Results 1 to 13 of 13
    Default Best 1 piece case for daily battery swapper ?
    I've never used a case on previous android or iphones, but this phone seems like an expensive accident waiting to happen.
    Since I pop the back off once a day to swap batteries, I don't want a two piece (gel + hard) case, or one which is a pain to take on and off.
    Any suggestions?
    Any other case-owning battery swappers out there?
    Thanks
    Mike
  2. #2
    taylorz_412's Avatar
    Posts
    Global Posts
    1,843 Global Posts
    ROM
    Clean ROM
    Default
    Blue tpu case from Verizon quick and easy Or I would recommend a diztronic case just look it up on amazonBest 1 piece case for daily battery swapper ?-imageuploadedbytapatalk1343617366.801550.jpgBest 1 piece case for daily battery swapper ?-imageuploadedbytapatalk1343617378.153187.jpg blue tpu from Verizon
    Sent from my retina iPad using tapatalk
  3. #3
    Default Re: Best 1 piece case for daily battery swapper ?
    I love my iFace case. $5 bucks, variety of colors, strong support all around the case and rear. Lines up perfectly leaving no gaps around the phone.
    Easily removable for battery swapping.
    . I got one from eBay and ten business days to arrive.
    If you don't mind waiting 20 days and paying only $3.14 shipped, you can go here:
    Sorry, in my hast, I forgot to mention that:
    I'm not concerned at all about scratching or scuffing of the phone.
    I would like to get some protection from falls.
    I would like some extra grip but I take it in & out of my pocket all day long so I don't want it soo grippy that it snags or tugs or is a hassle.
    Hope this helps clarify,
    Thanks,
    Mike
  5. #5
    firetruck41's Avatar
    Posts
    ROM
    Stock
    Default
    Diztronic works well for this. It is easy on/off, and offers decent protection. I have dropped mine from waist high, several times and the phone has been undamaged, the case seemed to "deaden" the fall and absorb shock. I have been "battery swapping" instead of plugging in, for the past week or two, much preferred to trying to always keep my phone plugged in when I'm not using it.
    Sent from my SCH-I535 using Android Central Forums
    Does the diztronic case slide in/out of pocket ok? is it too 'grippy'?
    thx
    mike
  7. #7
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    Default
    Get tep and if you break or lose it, you are only out 100$
    From my XxX rated Rezound
  8. Thread Author  Thread Author    #8
    I have 3 S3's in our family. To pay $10/month each ($30/month X 24 months) = $720 is too much.
    I'm going to 'self-insure'.
    If one happens to get destroyed, I could buy a Galaxy Nexus as a replacement for $400.
    In 2 years, my S3 will be worth $100.
    I feel lucky.
    Of course, I'll feel more lucky if I get a case!
    Mike
  9. #9
    Posts
    ROM
    Stock
    Default
    Duplicate post
  10. #10
    Posts
    ROM
    Stock
    Default
    Quote Originally Posted by pcguys View Post
    thx
    mike
    It slides in and out of a pocket easily, does not pick up lint or fuzz, looks good. Great value at $10, shipping included if you use Amazon Prime.
  11. Thread Author  Thread Author    #11
    Based on the suggestion in this thread, I got the diztronic case.
    My verdict: I LOVE IT!!!
    (Mind you, I have absolutely no experience with cases. I've always gone naked with all my iphones & androids, but after nearly dropped my phone 3 time I figured it was a sign.
    I had 2 concerns: I didn't want one too grippy so it was hard to take in & out of my pocket
    This has the perfect balance of grip and slide.
    I was also concerned about ease of taking it on & off when swapping batteries. NO PROBLEM.
    TWO THUMBS UP!
    (BTW, I ordered the body glove on sale for $4.99 so at least I'll have one other case to compare to.)
    Thanks everyone!
    Mike
  12. #12
    Default
    Seidio innocase is a two piece case but I take it off twice a day with relative ease to switch out batteries. I have 3 batteries and 2 external chargers so my phone is never on a charger. And it adds minimal bulk to the phone.
    Sent from my Rezound using Tapatalk 2
  13. #13
    meenas9's Avatar
    Posts
    Global Posts
    33 Global Posts
    Get the CPR Shield coverage from CPR Cell Phone Repair. I paid $30 for the year, if any accidental damage occurs, they fix it for a co-pay of $25.00!! No limit on how many times you can get it repaired. I went to the CPR in Orange County, California.
