Results 1 to 3 of 3
    Default Recommendations for extended battery, case, and car mount combo
    Just bought a Galaxy S3 and I want to buy an extended battery, case, and car mount/charging dock. I am having trouble finding a combination of all three that will fit/work with each other. The case I am considering now is the Seidio CSK3SSGS3XK-BK because I've read it will fit the anker 4400 battery. The problem is that I can't find a car charging dock/mount to fit this case. It seems that no matter what I choose, only 2 of the 3 items I want will be compatible with each other. The case must be a sturdy kind, like the ones with silicone on the inside and a hard outer shell on the outside. The battery should be as large as possible as long as it fits in the chosen case. The car mount can be windshield mounted or maybe top dash mounted, but NOT vent mounted. I am willing to sacrifice the larger extended battery if I must, but in that case I would still like to obtain the largest mAh capacity battery that does not require changing the battery cover. Any suggestions?
  2. Thread Author  Thread Author    #2
    Default Re: Recommendations for extended battery, case, and car mount combo
    130 views and no responses? Has nobody else ever wanted to use a car dock with an extended battery and case?
  3. #3
    Do want. 130 views is nuts.
    Did you ever find a solution to this?
  1. Charger and Case Question for Extended Battery
    By bobvanjr in forum Google / Samsung Galaxy Nexus
    Last Post: 09-03-2012, 02:46 PM
  2. What case for extended battery ?
    By Gpokmd in forum Thunderbolt Accessories
    Last Post: 04-28-2011, 07:49 PM
  3. Simple Pocket Pouch Case for Extended Battery Thunderbolt!
    By mahst687 in forum Thunderbolt Accessories
    Last Post: 04-27-2011, 03:51 PM
  4. Case for extended battery
    By chubbrock in forum Thunderbolt Accessories
    Last Post: 04-13-2011, 08:51 PM
  5. Case For Extended Battery
    By carguy10 in forum EVO Accessories
    Last Post: 04-11-2011, 09:57 AM
