Results 1 to 6 of 6
- 02-13-2013, 10:03 PM
Thread Author #1
Battery wall chargers
I've search ebay and amazon all of them are under 650mah output charge. Was wondering why are they so low and if you were to charge the battery in the phone is a lot stronger? Need one so I can charge and swap out extended batteries.
Galaxy S3 w/ Hyperion 4200mah and Seidio battery cover & ZeroLemon 7000mah - 02-13-2013, 11:38 PM #2
Re: Battery wall chargers
are you trying to say that you need a wall charger with a stronger output? I use this to charge my phone, it's 1.8A
- 02-14-2013, 07:52 AM
Thread Author #3
Galaxy S3 w/ Hyperion 4200mah and Seidio battery cover & ZeroLemon 7000mah - 02-14-2013, 09:04 AM #4
The 650 mA chargers will charge your extended battery, they'll just take longer. That may be OK if you're charging it overnight, say, to carry the next day.
The phone will apparently draw up to 800mA when charging, so it would charge a little faster in the phone, but not a lot. The 650 mA charger would charge a totally discharged battery in about 6 1/2 hours. Charging in the phone would take about 5 1/2. Remember, those estimates are for a totally dead battery. If you start recharging with about 25% of capacity left, the times will be shorter.PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
If I've helped you, please press the Thanks button.
Have a Galaxy S3? Click here ==> Everything you wanted to know about your Galaxy S3 - 02-14-2013, 09:11 AM
Thread Author #5
Galaxy S3 w/ Hyperion 4200mah and Seidio battery cover & ZeroLemon 7000mah - 02-15-2013, 01:04 PM #6
According to one member here, who said he's measured it, that's correct. I personally don't have a way to measure and verify that.
The GS3 isn't unique, btw. From what I've seen, no phone charges at more than 1 amp, max, regardless of what your charger is capable of. Limiting current flow protects the battery and charging circuit from over heating and over charging.PLEASE, when asking for help provide as much information as possible. Otherwise, it's like calling your doctor and saying "My head hurts." Your doctor can't treat you unless he knows whether you have a headache or a concussion, and we can't help unless we know what the symptoms are and what you did before they occurred.
Extended Battery Wall Charger
By chrisingrassia in forum Epic 4G Touch AccessoriesReplies: 5Last Post: 02-26-2012, 12:50 AM -
Batteries + wall charger + accessories on ebay
By aznmode in forum HTC EVO 3D AccessoriesReplies: 1Last Post: 07-06-2011, 02:29 PM -
Battery Wall Charger ? -Does it fit both standard & extended?
By jecilop in forum HTC EVO 4GReplies: 2Last Post: 06-30-2011, 11:14 PM -
Anyone order this 2-battery combo w/wall charger from Amazon?
By Android Addict in forum EVO AccessoriesReplies: 11Last Post: 01-09-2011, 09:38 AM -
Cordless wall charger and 2 batteries for sale.
By KMfiremedic111 in forum Samsung TransformReplies: 1Last Post: 12-12-2010, 11:55 AM
Reply
