1. volhater's Avatar
    I purchased an extra batter for my S3 to use while on vacation. I purchased it from AC store and it is the same battery that came with phone. However it has been charging for over 10 hours and never gets above 87% charged. Is this a bad battery or something else. Phone is powered off when charging . I turned it on to see where it was in charging since the green notification light never came on.
    06-19-2013 09:56 PM
  2. Dudetoo's Avatar
    Hi, run the battery flat and try recharging it again.
    Sent from my GT-I9300 using Tapatalk 2
    06-27-2013 02:58 AM
  3. Karl Thomas's Avatar
    Maybe you should try to charge and fully drain the battery for the first 3 cycles.
    07-01-2014 01:19 AM
  4. GTWalling's Avatar
    07-04-2014 11:01 AM
  1. Replacement battery doors?
    By Smokexz in forum T-Mobile Nexus S
    Last Post: 02-04-2011, 11:31 AM
  2. User Replacable battery
    By dajogejr in forum Verizon HTC Thunderbolt
    Last Post: 02-04-2011, 12:49 AM
  3. Replacement Battery
    By MK5 in forum Verizon Droid Incredible
    Last Post: 01-25-2011, 06:16 PM
  4. Replacement Battery Cover
    By sibion#WP in forum HTC Aria
    Last Post: 01-11-2011, 09:32 PM
  5. Replacement Battery Cover
    Last Post: 07-08-2010, 04:23 PM
