Results 1 to 17 of 17
    Yell0w's Avatar
    Posts
    Global Posts
    678 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Cyanogen 6.1
    Default S3 7000 mAh battery!
    Hello, just wondering if there are any users here that have one of the two batteries listed and their opinion about them. For some reason, there are so little reviews for the Hyperion...
    Hyperion: http://www.amazon.com/Hyperion-Exten...cUvbUpU2932635
    Zero lemon: http://www.amazon.com/warranty-ZeroL...cUvbUpU2932635
    Sent from my BN NookHD+ using Tapatalk 2
  2. Thread Author  Thread Author    #2
    Yell0w's Avatar
    Posts
    Global Posts
    678 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Cyanogen 6.1
    Default Re: S3 7000 mAh battery!
    Bump, would like some feedback from anyone that has one of these. Thanks.
    Sent from my SGH-T999 using Tapatalk 2
  3. #3
    badelhas's Avatar
    Posts
    Global Posts
    1,650 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.1.1 jelly bean
    I would also like to know. I already have a anker 4400 battery and would like to know if it's best to order the Seidio back door and Seidio Extended case to go with it or if I just should order this zerolemon 7000mAh Extended Battery which already comes with their own case. The price for ordering is more or less the same but would like some opinions from some one who tried them both.
  4. #4
    neonworm's Avatar
    Posts
    Global Posts
    3,232 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by badelhas View Post
    How much bulk does your 4400mah battery add to the phone? And, how much of an improvement do you have in battery life? I am thinking about getting one if it doesn't have too much bulk and adds a reasonable amount of battery life.
    Yell0w's Avatar
    Posts
    Global Posts
    678 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Cyanogen 6.1
    Quote Originally Posted by neonworm View Post
    I have read that the 7000mAh battery is the same bulk as the 4400mAh ones because it doesn't have a back cover, the case is what keeps it in place. Some have said that the 7000mAh will last 2-3 days but it's really based on the user usage.
    Sent from my SGH-T999 using Tapatalk 4
  6. #6
    badelhas's Avatar
    Posts
    Global Posts
    1,650 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    It adds some bulk and weight but it's acceptable because you battery lasts 2times more. But the design of the phone is ruined and I am still searching for a decent case. The Hyperion HoneyComb TPU Case sucks, the best option in terms of quality and looks seems to be the Seidio active extended case but it demands that you also buy their back door so it's an expensive option and the laza RuggedFusion hybrid case seems to be cheaper but not so good quality.
    neonworm likes this.
  7. #7
    Shelter7's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Yell0w View Post
    Hyperion: Amazon.com: Hyperion Samsung Galaxy S3 7000mAh Extended Battery + Free Black HoneyComb Extended Battey TPU Case (Compatible with Samsung Galaxy S3 GT-i9300, AT&T Samsung Galaxy S3 Samsung i747, Verizon Samsung Galaxy S3 Samsung i535, T-mobile Sa
    Zero lemon: Amazon.com: [180 days warranty] ZeroLemon Samsung Galaxy S3 7000mAh Extended Battery + Free Black Extended TPU Full Edge Protection Case(Compatible with Samsung Galaxy S3 GT-i9300, AT&T Samsung Galaxy S3 Samsung i747, Verizon Samsung Galaxy S3
    I used the Zerolemon battery you mentioned, I can recommend it
    No reason there are so little reviews for Hyperion, it`s not very reliable for an intense use, probably for customers using their phones just for calls and browsing from time to time
  8. #8
    irkenmodelgir's Avatar
    Posts
    Global Posts
    21 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    X with root, G3 with root
    I own the Hyperion one you posted (with Black case not white)
    Added a bulk and weight to it that was expected for it, as for battery life for the first 4 months with some moderate usage i would have to charge it every 3-4 days, and from my work where i had poor signal I would have to charge it about every two days. I have had it for about 6-7 months now and the only real issue i could chalk up to it is that With the summer being so hot and recent changes at my job i would try to leave the phone in the car. but the battery has started to expand (seeing as when i would get to my phone left in my glovebox the phone would state that the battery was around 119 degrees) but during this time before i stopped using it (for the bloating reason) the battery woulden't hold a charge for as long as before, which again i can't really falt the company for as heat will do that to any battery.
    I was looking at possably getting another of the same or maybe Ankers Amazon.com: Anker® 7200mAh Extended Battery Combo for Samsung Galaxy S3, I9300, AT&T I747, Verizon I535, T-Mobile T999, Sprint L710, U.S. Cellular R530 - TPU back cover included [18-Month Warranty]: Cell Phones & Accessories
    As for the Lemon, something just threw me off with there name, but might still be good.
  9. #9
    crammpa's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    How much mv would a fully charged 7000 mah zerolemon battery show?
    Sent from my SAMSUNG-SGH-I747 using AC Forums mobile app
  10. #10
    crammpa's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  11. #11
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by crammpa View Post
    Um, not sure where you're seeing ANY data like that in the stock software. Are you using a 3rd party application? If so, please post the link to it.
    A 3rd party application like Battery Monitor Widget http://market.android.com/details?id=ccc71.bmw might show the Voltage around 3800mV
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
  12. #12
    crammpa's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm using battery widget. I have noticed that when I charge the phone to 100%. I will unplug it and will immediately drop to 70% or 60%. I start to think that the battery was not fully charged and get stuck getting the stock battery readings.
  13. #13
    crammpa's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Since I have the Zerolemon 7000 mah in the phone shouldn't the capacity read as such?
    Attached Thumbnails Attached Thumbnails S3 7000 mAh battery!-1407089360529.jpg
  14. #14
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes, it SHOULD show the correct capacity (7000 mAh) - if it doesn't there may be something wrong with the app, in which case you should contact the developer (3c@3c71.com) or try a different app.
    You may need to reset the battery calibration data, which should be done automatically but can be done manually using BatteryCalibration http://market.android.com/details?id...erycalibration (but only if your phone is rooted). [If you want to root you can check out http://towelroot.com]
  15. #15
    crammpa's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm rooted. Thanks for the info.
  16. #16
    crammpa's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  17. #17
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by roger_2014 View Post
    wow its amazing.
    Enquiring minds want to know...
  1. Why is my battery draining when phone isn't being used?
    By Stav Edgar in forum Samsung Galaxy S4
    Last Post: 09-18-2016, 03:41 AM
  2. google servics waisting battery HARD
    By Lord_Crevil in forum Sony Xperia Z
    Last Post: 07-25-2013, 01:32 PM
  3. Need an urgent help ! Galaxy s3 cracked screen phone not working!
    By Bella Bellissima in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 07-21-2013, 08:01 PM
  4. samsung s3
    By sazlaw84 in forum General Help and How To
    Last Post: 07-21-2013, 11:16 AM
  5. Samsung galaxy s3 mini stopped downloading
    By Sarah2305 in forum Samsung Galaxy Acclaim
    Last Post: 07-21-2013, 08:20 AM
