Results 1 to 2 of 2
    Default Battery issues or phone?
    I've had my Samsung Galaxy s 3 for 5 months and I've had a couple instances in the last month where right after taking it off the charger and using it for less than 5 minutes the battery percentage would drop from 100% to 50% or less. And last night when I put it on the charger, completely dead, it did not start to charge. It stayed at 0% for at least an hour. I switched it into airplane mode in hopes to charge faster with no luck. Finally I turned the device off completely and it slowly charged to 28% overnight and was still not fully charged in the morning. Do I just need a new battery or a new phone?
  2. #2
    Default Re: Battery issues or phone?
    Sounds like a battery issue. Also I would check the USB cable/wall adapter your using I would lean more towards the USB cable first. If you have a different one try that and see if the outcome is any better. I've seen a bad cord have an " on/off " connection where it charges for a few seconds then stops, then starts again..
    Paul
    Moderator Team Leader @ Android Central
  1. Battery Has Gone Crazy on my Galaxy S3
    By Bebusy in forum Samsung Galaxy S3
    Last Post: 01-29-2014, 11:48 AM
  2. Verizon HTC One - 4G LTE Issues after 4.3 update?!?!?
    By Dakotabaker98 in forum Verizon HTC One
    Last Post: 12-31-2013, 09:06 AM
  3. Replies: 10
    Last Post: 12-27-2013, 11:09 AM
  4. WTB: An older AT&T phone
    By jdevenberg in forum The Marketplace - Buy, Sell & Trade
    Last Post: 12-27-2013, 03:25 AM
  5. OS Refresh, Scanning Bar Codes, & Photo Space Issues
    By RobMendez in forum T-Mobile HTC One
    Last Post: 12-27-2013, 02:18 AM
B
