1. Snipester's Avatar
    So recently i purchased an aluminium case off eBay for my international S3, installed, looks stylish as f**k, problem is, I noticed that my Wi-Fi signal is now lower, and unfortunately I am sure it's the cases' fault cause I tried taking it on and off and checking the signal, now, this is an issue I could live by, altough, recently I have noticed my battery drains much faster, could the case be affecting the battery life? Mind you, to fit the case I had to take off the back cover off the phone, I took some quick shots of the cover with my laptop so you can see.
    Galaxy S3: Aluminium case affecting signal and battery-win_20140321_140424.jpg
    Galaxy S3: Aluminium case affecting signal and battery-win_20140321_140411.jpg
    03-21-2014 08:11 AM
  2. dpham00's Avatar
    The aluminum case affects the signal, and weaker signal negatively impacts battery life. So yes an aluminum case could affect battery life. If the radios are turned off (airplane mode, no wifi or anything ), then it should not affect battery life
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    03-21-2014 08:44 AM
  3. Snipester's Avatar
    Got it, I removed the case, style over functionality doesn't work here
    03-22-2014 08:00 AM
  4. Spencerdl's Avatar
    I also had a bad experience with an aluminium case once, never purchased one again. I was glad that the Spigen Neo Hybrid (outer ring) was NOT made of aluminium, because it effects signal. I have the Neo on my Note3 and 5s...no problems with signal.
    03-22-2014 09:31 AM
  5. Illustrator Joe's Avatar
    Yup these things have been tested over and over. They look fantastic IMO but always affect signal in some way. It really is too bad.
    ಠ益ಠ
    03-22-2014 10:06 AM
  1. Replies: 15
    Last Post: 04-06-2014, 03:59 PM
  2. Replies: 3
    Last Post: 03-26-2014, 03:30 PM
  3. Battery useage - Looking for some insight
    By DinoF80 in forum Sprint LG G2
    Last Post: 03-22-2014, 02:52 AM
  4. Battery strength dropping after reboot
    By Soreloser in forum HTC One Google Edition
    Last Post: 03-21-2014, 06:45 PM
  5. Replies: 1
    Last Post: 03-21-2014, 04:12 PM
