Can you silence the camera click sound?
PaulQ
1,984
29
48
Yea, I want to sneak into locker rooms and take pictures of naked people.
Kidding.
Seriously, it's annoying. Scares my dogs. Makes people look at me when I'm taking legitimate pictures. My Resound let me turn it off.
Can you turn it off on the S3? Can't seem to find it.
Thanks!
Sent from my ASUS Transformer Pad TF700T using Tapatalk 2
On Verizon if you turn off the sound of on the home screen it turns off the clock.
Sent from my SCH-I535 using Android Central Forums
<sigh> So I need to cut sound altogether. OK. Thanks!
...Sent from my Prime Infinity
think some 3rd party camera apps have the option. i think its like law or something (maybe only in europe) that phones make a noise when u take a pic but dont think it affects 3rd party apps
The option is there (at least on the AT&T version).
Open the camera, tap the little gear icon (settings), scroll to the bottom of the settings list and you'll see the setting "Shutter sound." Tap it and select Off.
just checked + it defo isnt in european version
also not on the Verizon model.
but, not surprising. Verizon hates it's customers :-\
On my Verizon one I turned off sound on phone and no camera click
You have to go in the camera settings and then scroll down. I did not see it at first either.
Sent from my SAMSUNG-SGH-I747 using Android Central Forums
Yup have to put the phone on silent or vibrate. This would annoy me as well if I didn't keep my phone on vibrate all the time.
That's messed up that's it's not available on your phone.... AT&T is so rocking it these days... that's the first thing I did when I got my phone.....:cool:
~Jae, GS3 on Tapatalk~
FWIW, Google removed the option from official source/os. It is at the carrier and OEMs decision to give the option to turn this on and place the proper coding back into play to allow it. This is because there is privacy laws and such that Google did this.
Seems like Sprint is the only US carrier that has removed the option completely to disable the camera shutter sound.
Sent from my Nexus S 4G using Android Central Forums
I don't have that option on my Verizon S3. However, I can turn off ALL sounds (ringer, notifications, etc.), and it will silent the camera.
On the Telus branded S3, all you need to do is turn the ringtone down to vibrate / silent. You need to do this outside the camera app (or in pull-down menu, which you can actually access in all full-screen apps by swiping down from the edge)
WhichHomonym
