Results 1 to 6 of 6
- 01-24-2011, 09:26 AM
Thread Author #1
LauncherPro problems
So a problem I have is the fact that I want to run LauncherPro on my Galaxy S, but everytime I hit the "home" button I go back to the normal "HOME". Can I change this somehow?
// Thx for replying! - 01-24-2011, 09:34 AM #2
Exact same problem here. I have uninstalled reinstalled, nothing. :-(
- 01-24-2011, 09:36 AM #3
In the settings menu, the only way to change button behavior. It isn't broke, and re installs won't change it fyi.
★★★★★ - 01-24-2011, 01:30 PM #4
- 01-24-2011, 05:41 PM #5
Well I was able to fix it by installing a program called home switcher. This let me set LaucherPro as the default app. Once that was done I was able to go back to the settings.
- 01-25-2011, 04:08 PM #6
home switcher is another app you have to download so you can tell your default system to use this 3rd party home replacement screen.
Download HomeSwitcher and all your problems should be resolved.Make sure to thank anyone who provides you some help or clarification on here.
