- 02-03-2013, 07:51 AM
Thread Author #1
drain battery issue Rogers S3 I747M
Hi everyone
I have had my rogers Galaxy S3 Model I747M since last Sep 2012.But since last Dec 2012 (I think so) I'm looking for a solution for the drain baterry specialty in overnights.I did the reset factory but nothing happens, the battery still drain at night, the cellphone is all time Awake. Never is in stanby or when I left it in standby the battery continue working normally
I read and check a lot of websites but still I looking for the solution. So I have to wait for the upgrade??
Do any of you experience the same?
Any suggestions?
Samsung Galaxy S3 I747M - Rogers - 02-03-2013, 08:46 AM #2
- 02-03-2013, 08:52 AM
Thread Author #3
- 02-03-2013, 09:20 AM #4
- 02-03-2013, 11:52 AM #5
Re: drain battery issue Rogers S3 I747M
Don't be so quick to fault the device... there's probably some app that's keeping the phone active.
Post a screenshot of your battery screen. - 02-03-2013, 12:26 PM #6
- 02-03-2013, 12:40 PM #7
It would still be nice to see that Battery screen.
- 02-03-2013, 05:35 PM #8
Samsung Galaxy S3 SGH-I747M JB 4.1.1
LG Nexus 4 JB 4.2.1
--- - 02-03-2013, 07:11 PM
Thread Author #9
- 02-03-2013, 07:31 PM #10
LOL... taking a screenshot doesn't literally mean getting a camera and taking a picture of the screen of your phone...
Just swype the edge of your hand from right to left across your screen and the phone will save a picture of your screen to your phone. - 02-04-2013, 06:00 AM #11
Ummm not seeing the problem here either way? 21 hours on once charge for the standard 2100 mAh battery is pretty damn good!
LG Nexus 4 JB 4.2.1
--- - 02-04-2013, 09:21 PM #12
dude you most be alot of bg running while the data or wifi it on, when there off you should be fine. but if you don't look into it when you connect internet it going be running on the bg all the time to find out you need dw app call cpu spy plus and see how many % it your deep sleep mode
Here my
- 02-05-2013, 07:49 AM
Thread Author #13
Mhinc, I appreciate your time for the responses, thanks!!!
21 hours that you saw in the picture, even my I saw it, but this is false because the battery drain so fast, I can use at most 4 or 5 hours and then plugged in. 21 hs is a big lie!!.
Anyway, the day before yesterday I charged the battery 100% I pulled out the SD memory card and I fall asleep, I check the % when I woke up and the battery was in 94% That was great for my only use 6% in 8hours with wifi on. Last night I insert the Sd card again, I woke up 10 minutes ago and the battery is in 35%,(65% in 8hs) so I think I have some problem with the memory card, at least I found a solution!! I pulled out the memory and the battery it is working normally. - 02-05-2013, 08:33 AM #14
False Reporting? Wow that's a new one.....Also the Memory Card causing battery drain is a new one as well. Try a different memory card to make sure it's not a short in the MicroSD slot, and if it has the same issues with a different fresh card then I think it's time to contact Samsung for warranty!
LG Nexus 4 JB 4.2.1
--- - 02-05-2013, 10:13 AM
Thread Author #15
International Galaxy S3 Battery issues
By Qahir Lalani in forum Samsung Galaxy S3 I9300Replies: 5Last Post: 12-08-2012, 05:27 PM -
Samsung Galaxy s3 battery issues
By philip111 in forum Samsung Galaxy S3Replies: 1Last Post: 12-01-2012, 02:07 PM -
Battery Issues....S3/iphone
By joyfulmom2 in forum Samsung Galaxy S3Replies: 9Last Post: 10-29-2012, 02:20 PM -
Samsung Galaxy S3 battery issue.
By beachprance in forum Samsung Galaxy S3Replies: 9Last Post: 10-12-2012, 08:56 AM -
Battery issues; drains 40% overnight.
By ashakouri1 in forum HTC EVO 4GReplies: 13Last Post: 02-05-2011, 07:20 AM
Reply
