Someone in the Verizon forum posted this "solution" to many people's similar problem:
Thanks for the tip, but mine is stuck now in Downloading Android screen.... I'm connecting my S3 to a MacbookPro running OS 10.6.8 and the USB/Kies Wifi connection used to just fine (well, almost) until the latest Samsung firmware update, whatever version that was. Also Kies is updated to the latest version, but obviously it doesn't help either....
Is it only me or other people find that having to use pseudo hacks into what should work by itself are normal for an OS that's supposed to beat Apple's iOS?
I switched to GS3 from the iPhone for ease of use and what do I get? Updates and firmwares that screw up the phone? Looks like Apple all over again.
Shame on you Samsung and Google!
Make sure the Samsung drivers are installed. Power off your phone. Power on the phone in Download mode. (Volume Down + Home + Power) Press Volume Up to continue. Once it's in Download mode, plug it into your computer. Windows should now discover it and load the driver. Once this is complete, unplug the phone from the computer, and pull the battery out of the phone to get out of Download mode. Replace the battery, and power on the phone like normal. It should connect to the computer properly.
