Hi, I had my galaxy S3 from Rogers for almost 1 year and the battery drains like crazy!! When I first got the phone the battery life was ok. It lasted 1 full day (with the settings auto brightness, wifi usually on [when not in wifi area, using LTE], vibrate only, power saving on and snyc on. I turned off gps, bluetooth, location services, and motion). About 6 months ago I dropped the phone in water :S and I got it repaired. The phone battery life was still about 1 full day (with the same setting as above except when I'm not in a wifi area I use 4G to save battery life). After that every month the battery life seems to get worse from 1 full day to about half a day :S. After doing alittle research (this was around May/June) I found out Facebook was killing my battery so I stop using it on my phone then my battery got better (to about 3/4 of a day). But after that in July and August the battery life got really really bad, it will probably only last 5-6hrs. I honestly don't know what is wrong with it now. Is the water damage the problem with my battery drainage?
I'm running 4.1.2, never rooted and I'm running Nova launcher too.
