1. talltail13's Avatar
    Im not sure if its the new update because it worked for awhile after the udate. Now the voice commands for the camera dont work. In every settings thing ive tried nothing. Its there just grey so you cant turn it on. Please help this feature I use alot. Thnx
    12-26-2013 04:26 PM
  2. GTWalling's Avatar
    Have you by chance turned off SVoice?
    12-26-2013 08:55 PM
  3. timcary's Avatar
    I had the same problem. It only does that on easy mode.
    So I went to settings>my device>home screen mode. I choose Standard mode. Then I was able to switch on my camera voice control. it should work, say cheese.
    Mary Chocolates likes this.
    01-14-2014 04:25 PM
  4. michelleishappy's Avatar
    Settings>System>Voice Control has a box to check to reinstate voice commands for the camera on the GS3.
    I had the very same (frustrating) difficulty after the most recent update lol. Hope this helps!
    02-09-2014 07:21 PM
  5. Geir Friis's Avatar
    On my phone, it works only some of the time. Mostly not. Makes the feature not very usable. --Any solutions?
    Ps updated S-Voice to Galaxy S5 S-Voice
    04-12-2014 12:09 PM
  6. Anoop Narayanan's Avatar
    Change it to easy mode and then to standard then enable voice commands for camera, it will work
    05-03-2014 03:14 PM
  7. linnilu's Avatar
    No, it doesn't. Mine worked for a while and I loved it. Then it got unstable, working only part time. Now it does not work at all, even after following everyone's suggestions here.
    05-29-2014 11:34 AM
  8. CopperJohn's Avatar
    I have found one work around that works for me. I have to open the camera with the S Voice app using the audible voice command "Open camera". Voice command in camera then works. If however, I take a pic and then delete it when using the camera the voice command stops working again. I will then have to exit camera and again enter it through S Voice to get it to work again. If I enter the camera in any other way, the voice command does not work.
    06-19-2014 08:37 AM
  9. Ken Orlich's Avatar
    Totally true. This was the only suggestion that worked for me. Thanks!
    09-30-2014 01:09 PM
  10. jesse68's Avatar
    I was having the same problem with voice commands on my galaxy s4 camera. I opened Google then went to settings clicked on voice then on "ok Google detection" i unchecked the last 2 boxes after that i was able to take pictures using the word "capture"
    Side note: i am using TouchWiz standard on androids version 4.4.2
    I hoped this helps anyone who is still having issues using voice commands with their camera.
    GSDer and mars2304 like this.
    10-16-2014 09:43 AM
  11. mars2304's Avatar
    I was having the same issue on my note 3. I tried every single suggestion that has been in this thread. The one that finally worked was un checking the last boxes in ok google detection. I have idea how you figured that out.. But thank you so much for sharing!!! You cured my frustration.
    11-04-2014 09:10 PM
  12. Mary Chocolates's Avatar
    thank you it works
    12-20-2014 06:36 PM
  13. Diane Hughes's Avatar
    Great! Also the only suggestion that worked for me and my S3. Thanks~
    09-04-2015 08:16 PM
  14. MtheInsomniac's Avatar
    When flicking the Voice Control on & off in Settings, I was thankfully reminded that:
    "If you set the alert type for calls or alarms to vibration, voice command is not available"
    This explains its part-time behavior for me 😂 Glad I didn't opt to never show that reminder message again.
    09-19-2015 09:59 AM
  15. Mazdamobber's Avatar
    Open the camera then click the settings icon and scroll down to the bottom and I bet it's just turned off...
    11-14-2015 01:18 PM
  1. Keyboard with emoji's that work within Instagram
    By rob damiani in forum Keyboards
    Last Post: 01-04-2014, 03:17 AM
  2. CWM Not Working
    By FaithLV in forum Nexus 5 Rooting, ROMs, & Hacks
    Last Post: 12-31-2013, 02:57 AM
  3. Verizon Galaxy S3 - new message
    By atliens in forum Verizon Galaxy S III
    Last Post: 12-30-2013, 12:32 AM
  4. Video recording won't work on 4.3
    By Tim Y in forum Verizon HTC One
    Last Post: 12-28-2013, 10:54 PM
  5. Nexus 5 does work on MetroPCS!!!
    By E_Rosas in forum Google Nexus 5
    Last Post: 12-28-2013, 08:49 AM
