after i try to update my s3 mini i have booting problem its go ON bat only to the samsung logo then stop i try everything bat dos'nt help pls HELP MEEEEEEE PLSS
Printable View
Were you able to do a hard reset?
Press and hold VOLUME UP and Home(center) button
Press Power until the phone vibrate
Wait until you see the Android logo then release all the buttons.
Select Wipe data/Factory reset with VOLUME DOWN, press Power (right hand-side)
Select YES -- delete all user data with VOLUME DOWN and then press Power
After format, press Power again to reboot phone. (select reboot system now)
I was not able to hard reset my device , maybe the procedure is different ?
i have try it with VOLUME UP and home button i have press Power until the phone vibrate bat after i get not recovery mode it is the same LOGO FROM SAMSUNG :( i try it many time i get the same maybe samsung s3 mini have different procedure???!!!
yes i think new method, I am checking with samsung
thanx i am waiting for bro:)
If your phone was damaged by wrong flash file / firmware,
Or if you damaged the phone by trying to root it with i9300 CWM, the solution is [Only registered and activated users can see links. Click Here To Register...]
i have install NS PRO bat i get this message ............... ---------------------------
NSPro
NSPro box was not detected!
Make sure box is connected and try again!
OK
I have the same problem... you solved?
hello i have some problem with my galaxy but i found 1 solution to fix him ....press volume down+power+menu button to be in download mode....then go to Odin ...if you not have odin download here [Only registered and activated users can see links. Click Here To Register...] .... now download this [Only registered and activated users can see links. Click Here To Register...] and go to odin and press PDA ... Select the rar ..param. and connect your galaxy s3 mini and press start ....after phone work :p
- - - Updated - - -
hello i have some problem with my galaxy but i found 1 solution to fix him ....press volume down+power+menu button to be in download mode....then go to Odin ...if you not have odin download here http://forum.xda-developers.com/attachment.php?attachmentid=1168421&d=1341114315 .... now download this http://www.google.ro/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CCwQFjAA&url=http%3A%2F%2Fforum.xda-developers.com%2Fattachment.php%3Fattachmentid%3D1010806%26d%3D1334735069&ei=XvPtUPzFK9HKswa6wIGADQ&usg=AFQjCNGJ93WzuPXGyNnRSxBOzm4vK_sDlg&sig2=iQdLvVUkJ8eT3wEqmD-yeg&bvm=bv.1357316858,d.Yms and go to odin and press PDA ... Select the rar ..param. and connect your galaxy s3 mini and press start ....after phone work :p
you are awesome man thanx ,help me a lot
Thanks a lot! Problem solved.
hey all , i'm using no fault yet, very smooth and compact phone this is.... if you facing problem so come on gsm4shre.com, Mobile Phone unlocking Forum
hey isthis fixto fone rebooting by itself??
THX !!!!! YOU ARE AWESOME ! :DDDDDDDDd
thank u mate i was struggling but its now worked your a life saver
Hi I know it isn't a starting problem, but I downloaded the wrong rooted software (s3) an tried to install it via odin, my phone boots all fair an we'll, but I cannot install ANY application, not off play store, usually I get package file invalid, download any other apk install(unknown sources activated) the phone automatically throws out an error saying failed
can anybody help me i have a samsung mini s3 and the backlight keeps coming on and running my battery down when i went to 02 they said i had dropped it which i totally have not and they wanted £73 to repair it . is there any one who can help with this problem
