Results 1 to 12 of 12
- 02-01-2013, 09:17 AM
Thread Author #1
S3 Mini..battery drain problem :(
hi,
its my new S3 mini. I just updated it and since then the battry dies like crazy. Its 100% before I go to bed, next day its down to 30%.
Bluetooth and GPS are off. Its crazy. Anyone else with similar issue? Any idea what to do?
Damn you Update
- 02-06-2013, 04:09 AM #2
- 02-06-2013, 11:00 AM #3
- 02-06-2013, 11:13 AM #4
Re: S3 Mini..battery drain problem :(
It is a great app, but you would probably want to post some screen shots of your battery life and let some of these guru's around here see where the problems are at.... Also download gsam and that will tell you what is running.
Swyped from my Galaxy Tab 2 - 02-11-2013, 05:15 AM #5
- 03-28-2013, 05:07 AM #6
- 04-01-2013, 08:22 AM #7
hi,
I been having this problem recently and found that it was google talk that was the problem. After updating firmware battery was draining really quickly. Deleted everything and made no difference. I signed out of google talk and voila battery is back to normal
Hope this helps
galaxy s3 mini - 04-01-2013, 11:30 PM #8
- 04-03-2013, 03:31 PM #9
- 04-12-2013, 11:43 PM #10
- 04-24-2013, 07:33 PM #11
scuseme, could you tellme hoy to flash it with odin. i idded it on PDA in odin, but it fails.
<ID:0/010> Firmware update start..
<ID:0/010> boot.img
<ID:0/010> NAND Write Start!!
<ID:0/010> STE_boot1.img
<ID:0/010>
<ID:0/010> Complete(Write) operation failed.
<ID:0/010> Added!!
<OSM> All threads completed. (succeed 0 / failed 1)
could you help me please. - 05-10-2013, 07:29 AM #12
Hi there
Just an update, I had the same problem when I completed an ota upgrade, my battery just seems to drain very quickly. I updated the firmware via samsung kies, doing a a back as recommended by the software, so far my battery has been performing as it came out the box, perfect. It seems there was a glitch via OTA update. So far since last night with gaming, whatsapp and taking photo's, my battery seems to be only now on 41% and I charged it yesterday at about 3pm after the firmware update via kies.
galaxy s3 mini starting problem
By Avanti_nl in forum Samsung Galaxy S3 MiniReplies: 16Last Post: 05-16-2013, 02:46 PM -
S3 Battery Drain Problem. What do I do?
By Ben Hovinga in forum Samsung Galaxy S3Replies: 14Last Post: 05-10-2013, 11:44 AM -
ASUS Transformer Battery Drain Problem - the FACTS and SOLUTION
By ASUSFAN0001 in forum ASUS EeePad TransformerReplies: 37Last Post: 11-10-2011, 03:58 PM -
Battery drain problem: Any way to close all things running at one time?
By Garz in forum AT&T ATRIXReplies: 11Last Post: 02-25-2011, 02:06 AM -
Okay I may have found the battery drain problem
By splmonster in forum HTC EVO 4GReplies: 52Last Post: 08-06-2010, 07:33 AM
Reply
I was looking forward to get a mini and I might have some second thoughts.
