Results 1 to 3 of 3
    cutlass528's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default loose battery cover?
    I just purchased a Samsung Galaxy S3 Mini for my girlfriend and she's complaining because the battery cover does not appear to be secure. When I checked it, it does not click all the way around and there is a gap between the battery cover and the left (volume control) side of the phone. She wants to return the phone, I think the problem can be solved with a new battery cover. Any suggestions?
  2. #2
    GSDer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: loose battery cover?
    If you're within the 14 day exchange period, and you want to keep the girlfriend happy, you should return the phone and get a brand new one that has no defects (as the girlfriend wishes - unfortunately, they're right most of the time).
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
  3. #3
    Fairclough's Avatar
    Posts
    Global Posts
    3,997 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    One sentence...
    Keep the misses happy.
    - Android Central App. Remember courage is contagious.
  1. 4.3 battery info
    By Rcrdude64 in forum Sprint Galaxy Note 2
    Last Post: 12-15-2013, 11:31 AM
  2. Samsung galaxy S3 battery drain
    By tfromero in forum Samsung Galaxy S3
    Last Post: 12-10-2013, 02:08 PM
  3. Good battery saver app for N4 with 4.4?
    By billdz in forum Google Nexus 4
    Last Post: 12-09-2013, 03:34 PM
  4. Using note while using external battery, discharge rate?
    By Bruno Alves2 in forum Samsung Galaxy Note 10.1
    Last Post: 12-07-2013, 07:41 PM
  5. Nexus 4 battery broken?
    By Kolli63 in forum Google Nexus 4
    Last Post: 12-07-2013, 03:15 PM
