Results 1 to 3 of 3
    Default Samsung Galaxy S3 Mini - Battery problem
    I've had this cellphone for no longer than 10 months and now it is starting to get some serious troubles.
    The first one is that it doesn't charge completely. I can charge it the whole night with it turned off and it won't go higher than 80%. And the charging symbol remains on the battery icon even after I remove it from the charger and I have to restart the phone to get it off.
    The second problem is that the battery is draining way to fast. Like in two hours, even if I am not using it. At first i thought my battery was messed up so I bought another original one but the problem is still here.
    The third problem is that it is overheating and slowing the processor down.
    Help?
  2. #2
    Default Re: Samsung Galaxy S3 Mini - Battery problem
    Buy a new?
  3. #3
    Seen this before on my mates s3 mini it is the USB charging port there will be a damaged pin in it. You can have it repaired but you should also make sure that the charger is changed as well. The parts are cheap about 5. There is also videos on YouTube to do it Yourself
  1. Samsung Galaxy S4 - constant crashing
    By AndroidTuttons in forum Samsung Galaxy S4
    Last Post: 12-11-2013, 09:40 AM
  2. Kasperksky and S3 update to 4.3
    By jerprinzen in forum Samsung Galaxy S3 in Canada (Bell/Telus/Rogers)
    Last Post: 12-10-2013, 11:24 AM
  3. Galaxy Gear NOT Compatible with GN 10.1 2014 WiFi Edition
    By Raptor007 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 12-08-2013, 10:35 AM
  4. Sony Xperia Z Ultra - Blank Screen problem on Call
    By Venkatesh Vandanapu in forum Sony Xperia Z Ultra
    Last Post: 12-08-2013, 09:28 AM
  5. Replies: 0
    Last Post: 12-08-2013, 08:52 AM
B
