Results 1 to 3 of 3
    Default Samsung Galaxy S3 Mini HELP?
    Hi i have a Samsung galaxy s3 mini it is unlocked to any network but recently it has stopped getting signal. when a Sim is put in it recognizes the Sim as Vodafone or what ever Sim it is. the phone will not let you select the network carrier in the choose operator option in the settings it will just say each time "unable to connect" with a constant "emergency calls only" displayed the phone inst locked or switched off. when i try and make calls it says "not registered on network"
    i have don't the following:
    i have rooted the phone and upgraded the firmware to try and fix
    i have reset the phone a number of times
    tried every UK network Sim in the phone
    the phone is no longer under warranty "reason for root"
    the following is displayed in the about phone option
    Network: unknown
    signal strength: -107dbm 2 asu
    service state: out of service
    Roaming: out of roamingClick image for larger version.
    running android 4.1.2
    any help will be great thanks
  2. #2
    Default Re: Samsung galaxy s3 mini HELP?
    Have you tried the SIM in another device? Is the SIM card active on your number?
    Posted via Android Central App on my Samsung S3 mini
  3. #3
    Seems like the imei could be blocked.....or the Sim slot is bad.... Don't really know.
    Sent from my Nexus 4 using AC Forums mobile app
  1. Galaxy Tab 3 7.0 Home button repalcement
    By rostock in forum Samsung Galaxy Tab 3
    Last Post: 08-21-2014, 05:32 AM
  2. Undelete File Motorola XT890 RAZR I NEED HELP!!!!!
    By volkerc01 in forum Android 4.0 Ice Cream Sandwich
    Last Post: 01-15-2014, 06:27 AM
  3. battery problem (samsung galaxy grand quattro)
    By 786chatur in forum General Help and How To
    Last Post: 01-09-2014, 01:28 PM
  4. Galaxy gear disables speaker on S4
    By jdr004 in forum Samsung Galaxy S4
    Last Post: 01-09-2014, 09:17 AM
  5. Help with RAM/running apps?
    By Marvin-13 in forum HTC One M7
    Last Post: 01-09-2014, 07:34 AM
