Results 1 to 3 of 3
    Qrczak's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default S3 mini with S3 (2100 mAh) or Ace3 (1800 mAh) battery?
    Hi,
    Recently I have found info, that someone uses S3 batt (2100) in his Ace3 LTE (originally it has 1800 batt).
    Is this possible? I mean, S3 is a 'bit' bigger than Ace3... And if the batt fits, isn't it going to damage phone?
    Other thing is, that Ace3 has two versions - LTE and non-LTE. Besides LTE and CPU, one of the differences is battery - LTE ver has 1800mAh batt, non-LTE - 1500 mAh. And, since S3 Mini and Ace3 both have same dimensions, maybe it would be possible to use Ace3 LTE batt in S3 Mini?
    /Q
  2. #2
    ioansuhov's Avatar
    Posts
    Global Posts
    294 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: S3 mini with S3 battery (2100mAh)?
    I had both an S3 and an S3 mini, and I remember that the difference, in size, of the batteries was noticeable. I strongly believe that an s3/ace3 etc battery won't fit the S3 mini.
  3. #3
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    If the battery dimensions are exactly the same, then maybe you'd be able to use it. I highly doubt they'd be an exact fit, and if it did, you'd still need a bigger battery door.
    Sent from my Galaxy S4 running Slim Bean 4.3
  1. Battery sales and OEMs.
    By tedsc in forum General News & Discussion
    Last Post: 02-16-2014, 01:39 PM
  2. Battery draining faster with Spark
    By Robynsnest in forum Sprint LG G2
    Last Post: 02-12-2014, 05:40 PM
  3. Sprint S4: Help with SuperSU not working on MK2 rooted!!!
    By DASHZNT in forum Sprint Samsung Galaxy S4
    Last Post: 02-08-2014, 12:51 PM
  4. Replies: 8
    Last Post: 02-08-2014, 11:39 AM
  5. Did KK come with a new version of Sense too?
    By TBoltJ in forum Verizon HTC One
    Last Post: 02-07-2014, 11:53 AM
