1. anamelle's Avatar
    Gahh... My phone wasn't charging well (1-6% ish) so I moved it to the other plug socket in my room, where it charged just fine. I checked plug no. 1 with other electrical items but they worked well and showed no problems. When my phone had charged to about 60% I moved it back to the original socket as it was closer to my bed (so I can hear my alarm), where it didn't charge, but after I wiggled it around it began to charge, slowly at least. I woke up to find my phone dead, it doesn't turn on at all, no matter what socket or charger I use. The charger does work on the other phones I've tested so there shouldn't be a problem there... Help!
    P.S: I did a system update (not sure if related to problem) a few days before this.
    P.P.S: There is a small crack on the grey 'rim' (?) where the charger input thing is.
    02-20-2014 07:20 AM
  2. Golfdriver97's Avatar
    Welcome to the forums.
    Since it appears the charging port is damaged, that would be part of the problem. I would see if you can find a shop that can repair it, and then charge the battery for several hours.
    02-20-2014 09:19 AM
  1. sd card will not store files and wi-fi no longer works
    By James Francis1 in forum LG Optimus L
    Last Post: 02-20-2014, 10:13 PM
