1. Steve Hall1's Avatar
    hi I have a 12 month old S3 mini. after a full charge within about 1 hour of very little use battery power status drops to empty (with the exclamation mark symbol) screen also goes into low light mode. The phone stays like this for a couple of hours then dies. any ideas. thanks
    03-24-2014 04:37 PM
  2. GSDer's Avatar
    Sounds like your battery is kaput.
    You could put it in Airplane mode just to be sure that there's not a signal issue that's killing the battery (I've had that happen before).
    You could also try Safe mode http://support.verizonwireless.com/s...ase.html/59242 to be sure it's not some 3rd party app(s) causing the problem.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    03-24-2014 11:09 PM
  1. Galaxy S4: KitKat Micro SD Deleting Problem after Update
    By Ur_Face2014 in forum Android 4.4 KitKat
    Last Post: 07-08-2014, 10:37 AM
  2. Replies: 2
    Last Post: 03-31-2014, 05:15 AM
  3. Note 3 uses way too much battery!
    By Yas112 in forum Samsung Galaxy Note 3
    Last Post: 03-28-2014, 05:35 AM
  4. WiFi connection problems and Static IP setup issue
    By MaxSplatter in forum US Cellular Galaxy SIII
    Last Post: 03-25-2014, 11:36 AM
  5. SII mini not connecting to wifi - Too many redirects.
    By Mophead123 in forum Samsung Galaxy S II
    Last Post: 03-24-2014, 11:51 AM
