1. Ali_K_12's Avatar
    Hi, my s3 mini was charging this morning to about 30/40% I then took it off charge to use it as I was out. The battery then went dead, I got home about an hour later and it won't charge. I have tested the charge on my SG tab and it charges fine. Any suggestions??
    04-17-2014 04:00 PM
  2. Ali_K_12's Avatar
    bump
    04-20-2014 06:44 AM
  3. GSDer's Avatar
    Welcome to the forums! Sorry you didn't get an earlier response.
    Did you read through the various charging threads to see if they had anything to offer?
    Typically you'll want to take the battery out for a few minutes, then reinsert it (but don't attempt to turn it on) and connect the charger. You should see a static battery graphic followed by another graphic showing the battery level and charging activity. Leave it overnight if you have to.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    04-20-2014 09:55 PM
  4. Ali_K_12's Avatar
    Yes I did remove it left it overnight e.t,c and it won't charge, there's no lint/dust in the USB port either, thanks.
    04-22-2014 08:04 PM
  5. GSDer's Avatar
    Hmm...how old is the battery?
    I don't suppose you know anyone else with a Mini?
    04-23-2014 12:11 AM
  6. Ali_K_12's Avatar
    No unfortunately I don't I bought the phone as i liked android but the S3 was too big for my taste, had I had an S3 now I could have simply borrowed a friends battery ='D
    04-23-2014 04:01 PM
  1. Galaxy S 5 Beep while charging
    By Jasburyy in forum Samsung Galaxy S5
    Last Post: 06-20-2016, 11:00 PM
  2. Sprint Galaxy S3 updating problem
    By congaman59 in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 05-11-2014, 08:26 PM
  3. .mobi .epub file problem
    By Hendo255 in forum Samsung Galaxy S5
    Last Post: 04-27-2014, 01:27 PM
  4. 4.4 for Samsung Galaxy S3 GT-I9300
    By HarryDevice in forum Samsung Galaxy SIII I9300
    Last Post: 04-18-2014, 01:54 AM
  5. Charging port issue, now screen wont come on, any ideas?
    By chuckdog_5 in forum AT&T Galaxy Note 2
    Last Post: 04-17-2014, 01:31 PM
