1. Frederik_dass's Avatar
    Hello...
    I had this problem about 3-4 months ago.
    I've tried everything to turn on my BT. Restart the phone, unplugged battery, It didnt work at all!
    And recently I did a factory reset.
    It's ok. My BT back to normal and be able to turn on again.
    But... It's very unbelievable... after I did a full restore (Including system data restore), My bluetooth won't able to turn on again!
    Since that, i realized that the problem caused by an app/running process but unfortunately i can't guess it.
    I really disappointed of this. It's impossible to do a factory reset again because it's just wasted my time to do a restore again.
    I need you guys help the way to detect what apps caused this.
    I really need your help,
    Or how to complaint this to samsung developer?
    Thanks in advanced.
    04-29-2014 06:10 AM
  2. GSDer's Avatar
    Hi, and welcome to the forums!
    Um, no - what's impossible is for us to guess what apps you might have installed, and which of those may be causing your problem.
    You could try booting into Safe mode http://support.verizonwireless.com/s...ase.html/59242 and if Bluetooth works fine then you can be certain that it's a 3rd party application causing your problem.
    You should have SOME idea when looking through your apps list of what they do - start by uninstalling any that have anything to do with Bluetooth or power management or that provide control toggles.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    04-29-2014 02:52 PM
  1. Help-Cannot connect to open (unsecure) Wi-Fi if...
    By lkjhbmonlj in forum Samsung Galaxy Note Pro 12.2
    Last Post: 02-08-2017, 07:17 AM
  2. PLEASE HELP! S4 just died...for no reason.
    By DudeThatsErin in forum T-Mobile Samsung Galaxy S4
    Last Post: 04-18-2016, 05:30 AM
  3. Galaxy S5 on Sprint - Beeping
    By rockpaper in forum Samsung Galaxy S5
    Last Post: 05-21-2015, 07:12 AM
  4. Replies: 31
    Last Post: 11-05-2014, 06:37 PM
  5. How to submit an app for review on androidcentral.com ?
    By Dheeraj Batra in forum General Help and How To
    Last Post: 04-29-2014, 12:56 AM
