1. Carla Davidson's Avatar
    Hi, the battery keeps dying. I have to charge it every couple of hours even without being used. Apparently it charges fast but it doesn't last. How do I know if it's the battery or the cell? Can I do anything to fix it?
    Thanks in advance
    05-21-2014 05:23 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! You can remove the battery, lay it flat on a table, and try spinning it--if it spins freely, that means it's bulging in the middle and is therefore going bad. That definitely means you should replace it. But even if it isn't bulging, it's worth trying a new battery to see if the problem persists.
    05-21-2014 10:06 PM
  1. Any experience with Zagg or Verizon protectors?
    By lucasbuck in forum Samsung Galaxy Note Pro 12.2
    Last Post: 07-06-2014, 04:58 PM
  2. Wifi or Router issues on my HTC One?
    By GregIsARadDude in forum HTC One M8
    Last Post: 05-23-2014, 01:10 PM
  3. Battery Question.
    By parkerd97 in forum HTC One M7
    Last Post: 05-23-2014, 12:27 PM
  4. Old SD card? Mediaserver maybe draining your battery!
    By jackoceanz in forum HTC One M8
    Last Post: 05-21-2014, 07:20 PM
