Results 1 to 6 of 6
    Default Firmware upgrade encountered an issue
    Hello everyone, I have aproblem with my Samsung Galaxy S3 mini (GT-I8200). I cannot get into download or recovery mode. Regardless of what combination of buttons I push, I always get to the same screen: "Firmware upgrade encountered an issue. Please select recovery mode in Kies & try again."
    Whenever I plug in my phone my Windows tells me "USB device not recognized" so it does not get picked up by Odin. I have installed 5 different versions of "Samsung usb phone drivers" few times and I still get the same message. I have tried few other solutions that I found but it didn't didn't work. Is there anything I can do to fix this or can I start using my Samsung as a ****ty coaster? :/
    Any information will be appreciated.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,730 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Firmware upgrade encountered an issue
    Since you can't get into either recovery or Download, you may have to look at a JTAG service. Do you know what happened to cause this?
    Thanks for replying. I was trying to install CyanogenMod 11. Dono much about JTAG, can I do that myself or will I have to take it to a tech store?
  4. #4
    Welcome to the forums!
    Quote Originally Posted by ForeignKid View Post
    You'll have to take it in - JTAG uses specialized hardware and software to access the phone memory directly. Ex.
    http://mobiletechvideos.mybigcommerc...-brick-repair/
    http://www.fonefunshop.co.uk/Unlocki...oot_repair.htm
    It's rather unusual that the phone won't enter Download mode - you've successfully entered that mode before, right?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    Yes I have successfully entered the download mode when I tried putting the CyanogenMod on with Odin. The last time I was able to access the download mode, Odin's message was "All threads completed. (success 0 / failed 1)".
  6. #6
    The only thing I could suggest besides JTAG would be to see if you can load a debrick image for your device. It's pretty rare to need this so I don't even have any links for you but a Google search should turn up something. IIRC the debrick image will be model specific (i.e. you can't use one for the T-Mobile variant on an AT&T device) and it's also size specific (there's a different file for a 32GB version vs. a 16GB version). Good luck.
  1. What is the Complete Procedure to Create an Application
    By Greco14 in forum Ask a Question
    Last Post: 09-05-2014, 03:26 PM
  2. Galaxy S4 Camera/Screen Issue!
    Last Post: 08-25-2014, 02:38 AM
  3. Can not clear data for an application
    By avgasn in forum Samsung Galaxy S5
    Last Post: 08-25-2014, 01:17 AM
  4. Verizon Galaxy S5 - Anyone run into this issue? Samsung Knox Counter Went missing!
    By Djuno420 in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 08-24-2014, 09:57 PM
  5. Replies: 1
    Last Post: 08-24-2014, 02:37 PM
