1. SayIDidIt's Avatar
    I have a Galaxy s3 mini and I tried rooting and installing KitKat but I've been having some issues.
    Here is what I did:
    Downloaded Odin and Kies (for the phone drivers, Kies was closed while using Odin)
    Downloaded CMW Recovery and a root.zip file
    Flashed CMW and placed the root.zip on extSD card.
    In Recovery mode, backed up system then installed the root file.
    Downloaded Root Checker and it said I have root.
    Then downloaded slim4.4_golden. nova.20140630.zip and a gapps file and placed them both on the extSD.
    Using Recovery (Vol Up+Home+Power), wiped data and davika (whatever it's called) and then flashed slim4 file. But got a "Bad" message.
    I then tried cm11.0_golden.nova.20140823.zip which went smoothly and then gapps-kk-20140606-signed.zip but in middle it stopped with an error and said something about process 7 (I think).
    I tried it a couple of times.
    Also, I'm not sure if Root is working 100%. For one example, AdBlock is not blocking ads, even though it says "Ads are blocked on all connections" but I'm still getting ads galore.
    Anyone know what I should do? Would it be better to go through Odin instead of Recovery (using Odin compatible files, of course)?
    Thank you very much!
    08-28-2014 03:00 AM
  2. AndroidProf's Avatar
    As far as I remember this is an error that's caused by CWM incompatibility. Try flashing TWRP onto your phone and then flashing the gapps. Alternatively, if that's a hassle and you have a backup in CWM, i would recommend getting Odin compatible files and flashing them through Odin because to restore a CWM backup you need to have CWM installed on your device.
    08-29-2014 02:54 AM
  1. Huge Problems After 4.4.3 AT&T Update
    By ptakistan in forum HTC One M8
    Last Post: 10-02-2014, 12:59 PM
  2. Replies: 2
    Last Post: 08-28-2014, 04:14 PM
  3. samsung note 3 charging problem
    By Farhana1234 in forum Ask a Question
    Last Post: 08-28-2014, 01:21 AM
  4. Replies: 1
    Last Post: 08-27-2014, 06:39 PM
  5. text messages from my phone to my laptop? Help !!!
    Last Post: 08-27-2014, 05:38 PM
